Home > Technical (L322) > Door won’t close!
Slow progress
Door won’t close!
Hi Everyone and seasons greetings!
I’m just having the weirdest issue, I opened my drivers door this morning, handle appeared to stick open with the frost but pushed back in , now the door won’t shut. It’s like it’s not catching and just bouncing back.
Have I broken something? Is there a way to get it to close so I can get it locked up for now L322 TD6 2003
Epsom Green- the dogs car which has worked it’s way into being the family car 😮
Post #650166 8th Dec 2022 4:41pm
the latch is probably still frozen....hairdryer? to un-freeze it and then insert much grease.... ... - .- -.
Post #650170 8th Dec 2022 5:03pm
Slow progress
Hi Stan,
Thanks for that. I’ll give it a shot.
Mind you I’ll have to ask the wife for hers as I no longer require one….indeed my wife bought me rain x for my birthday….for my head!! Shocked L322 TD6 2003
Post #650177 8th Dec 2022 5:51pm
Discotigger
I had the same problem last year. I held the door closed and operated the central locking. That closed the latch and locked it, then reopened and everything worked after that.
Post #650179 8th Dec 2022 6:09pm
Tdtj
Scotland 2016 Range Rover Autobiography SDV8 Santorini Black
I had the same problem with my interior handle on Tuesday night. Obviously frozen absolutely pita to get back to working again,probably about ten minutes or so Ahhh the joys 2016 4.4 diesel
Post #650195 8th Dec 2022 7:27pm
Had the same yesterday morning, right pain it was. Got - 2017 SDV8 Autobiography in Loire Blue
Post #650200 8th Dec 2022 8:02pm
322BLL
Estonia
To get it fixed you need to remove the door card and with flashlight look how the cable and door handle move while you pull/release the handle. Some good weather resistant spray with straw. Take the cable off and spray it. Spray the handle moving mechanism. All back together. Mine has been good for few years now and we have weeks and months with temps constantly below 0, meaning the door will not open and you need to use passenger door to get in and out or which ever works..
If you get inside there and see how the outer cable is located and how it moves, it is easy to understand why the cable get’s stuck and won’t return inside the housing when friction is to high. And why it’s just a question of time when it snaps Whistle
Post #650428 10th Dec 2022 9:26pm
Rosco
Pour a kettle over the handle, every year I have the same issue when it gets well below zero Thumbs Up
Post #650440 11th Dec 2022 8:43am
TDV8 Paul
Had the same thing happen to me- once it thawed I sprayed some ptfe lubricant that I had lying around as that’s all I had- I’ll see how successful it was in the morning 😂 2009 (2010 MY) 5.0 Supercharged Autobiography
2007 TDV8 Vogue SE
2005 BMW E63 645ci
2024 Porsche Macan
Post #650514 11th Dec 2022 10:22pm
TorontoDee
Canada 2012 Range Rover Westminster 5.0 SC V8 Santorini Black
Happened to me a year ago, ended up having the cable & latch kit replaced at a Dealer here in Toronto. All was fine until this morning when it occurred again (cold, wintry windy wet snap) Sad
If someone knows what's involved to get in to the door so I can spray/lubricate it myself, please share Smile 2012 Supercharged L322
Post #650582 12th Dec 2022 4:40pm
TDV8 Paul
The ptfe lube worked a treat- opened this morning no problem 2009 (2010 MY) 5.0 Supercharged Autobiography
2007 TDV8 Vogue SE
2005 BMW E63 645ci
2024 Porsche Macan
Post #650601 12th Dec 2022 7:24pm
grayst01
Scotland 2012 Range Rover Vogue 4.4 V8 Java Black
Typically after reading this thread last night my own passenger door wouldn’t lock over after I had opened it this morning at 5am to throw my bag on the seat… Big Cry with a nice -7C on the dash that wasn’t ideal!
Short of any heating up/messing about I just leaned over and held the door closed from the inside and pushed the central locking button on the dash to lock all the doors, and hey presto it worked… all good! Thumbs Up
I should also say this was after having preset my FBH for the first time to kick start at 4:45am just to see if it was working - and it bloody did. Lovely. Bow down Cheers, Steven.
2012 Vogue 4.4 TDV8.
Post #650602 12th Dec 2022 7:35pm
TorontoDee
Dealer said it's covered for a year under warranty. so I'll wait for it to happen again, record it using my phone, and make an appointment to take it in before I go about figuring out how to disassemble part of the door to spray and grease it up when it happens again after that 😂 2012 Supercharged L322
Post #650613 12th Dec 2022 9:47pm
TDV8 Paul
I lied- my drivers door lock was frozen shut again this morning 😂 2009 (2010 MY) 5.0 Supercharged Autobiography
2007 TDV8 Vogue SE
2005 BMW E63 645ci
2024 Porsche Macan
Post #650636 13th Dec 2022 9:43am
TorontoDee
Ditto for me. Decided to try it while the ignition got everything going this morning at 0545 before leaving for the gym, and whatever it is, tensioner or outside handle, the -10 weather caused it to fail. So, recorded it with my phone, emailed the dealer, got in and reached across to hold it closed and pressed the lock button in the main instrument panel to latch it, and away I went to workout.
I'll drop it off tomorrow morning, and hope they don't need to keep it until Monday! 2012 Supercharged L322
Post #650653 13th Dec 2022 2:57pm
