Home > Technical (L322) > Door won’t close! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35291 |
the latch is probably still frozen....hairdryer? to un-freeze it and then insert much grease.... ... - .- -.
8th Dec 2022 5:03pm |
Slow progress Member Since: 30 Jun 2020 Location: Derbyshire Posts: 451 |
Hi Stan,
8th Dec 2022 5:51pm |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 |
I had the same problem last year. I held the door closed and operated the central locking. That closed the latch and locked it, then reopened and everything worked after that. |
8th Dec 2022 6:09pm |
Tdtj Member Since: 29 Sep 2021 Location: Edinburgh Posts: 185 |
I had the same problem with my interior handle on Tuesday night. Obviously frozen absolutely pita to get back to working again,probably about ten minutes or so Ahhh the joys 2016 4.4 diesel |
8th Dec 2022 7:27pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6723 |
Had the same yesterday morning, right pain it was. Got - 2017 SDV8 Autobiography in Loire Blue
8th Dec 2022 8:02pm |
322BLL Member Since: 18 Apr 2019 Location: Estonia Posts: 73 |
To get it fixed you need to remove the door card and with flashlight look how the cable and door handle move while you pull/release the handle. Some good weather resistant spray with straw. Take the cable off and spray it. Spray the handle moving mechanism. All back together. Mine has been good for few years now and we have weeks and months with temps constantly below 0, meaning the door will not open and you need to use passenger door to get in and out or which ever works..
10th Dec 2022 9:26pm |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2575 |
Pour a kettle over the handle, every year I have the same issue when it gets well below zero |
11th Dec 2022 8:43am |
TDV8 Paul Member Since: 30 Nov 2020 Location: Tadworth Posts: 223 |
Had the same thing happen to me- once it thawed I sprayed some ptfe lubricant that I had lying around as that’s all I had- I’ll see how successful it was in the morning 😂 2009 (2010 MY) 5.0 Supercharged Autobiography
11th Dec 2022 10:22pm |
TorontoDee Member Since: 27 Sep 2022 Location: Toronto Posts: 67 |
Happened to me a year ago, ended up having the cable & latch kit replaced at a Dealer here in Toronto. All was fine until this morning when it occurred again (cold, wintry windy wet snap)
12th Dec 2022 4:40pm |
The ptfe lube worked a treat- opened this morning no problem 2009 (2010 MY) 5.0 Supercharged Autobiography
12th Dec 2022 7:24pm |
grayst01 Member Since: 08 May 2022 Location: Glasgow Posts: 104 |
Typically after reading this thread last night my own passenger door wouldn’t lock over after I had opened it this morning at 5am to throw my bag on the seat… with a nice -7C on the dash that wasn’t ideal!
12th Dec 2022 7:35pm |
Dealer said it's covered for a year under warranty. so I'll wait for it to happen again, record it using my phone, and make an appointment to take it in before I go about figuring out how to disassemble part of the door to spray and grease it up when it happens again after that 😂 2012 Supercharged L322 |
12th Dec 2022 9:47pm |
I lied- my drivers door lock was frozen shut again this morning 😂 2009 (2010 MY) 5.0 Supercharged Autobiography
13th Dec 2022 9:43am |
Ditto for me. Decided to try it while the ignition got everything going this morning at 0545 before leaving for the gym, and whatever it is, tensioner or outside handle, the -10 weather caused it to fail. So, recorded it with my phone, emailed the dealer, got in and reached across to hold it closed and pressed the lock button in the main instrument panel to latch it, and away I went to workout.
13th Dec 2022 2:57pm |
