![]() | Home > Technical (L322) > Electronic Handbrake Fault |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3192 ![]() ![]() ![]() |
I unplugged the multiplug to the rear diff, the rear diff temperature sender, and the handbrake module and then removed the rear left wheel to access the wiring loom through the wheel arch.
tuchubby Member Since: 30 May 2023 Location: Phoenix, Arizona Posts: 2 ![]() ![]() ![]() |
What does U3000-4B entail? Description says control module but no clue on how to approach. |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
Hi David
- - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
My car had the electronic locking diff so it had a multiplug on the motor and the temperature sensor. They’re tucked up out of the way, however, if you’ve not got the locking diff you’ll not have them.
HI David
Which is switch or cable it seems. https://www.fullfatrr.com/forum/post683447.html#683447 Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
Mine is a standard diff so I just need to find my connector. Just hoping to get a steer where to look. Up around the EPB module I guess? . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
The handbrake module lives on top of the subframe. The connector into that module is on the NS of the car on the top of the subframe. It’s an awkward sod to get to.
amazing thank you David.
Think I found the little
update: behaving, behaving behaving then this morning faulting again on MOT test day. crap. I'm at the MOT station.....
fredd589 Member Since: 24 Apr 2024 Location: Cambridge Posts: 19 ![]() ![]() ![]() |
Hey GGDR,
I removed the rear discs, cleaned up the drums, lubed it all
