Home > Technical (L322) > Electronic Handbrake Fault |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3145 |
I unplugged the multiplug to the rear diff, the rear diff temperature sender, and the handbrake module and then removed the rear left wheel to access the wiring loom through the wheel arch.
31st May 2023 11:14am |
tuchubby Member Since: 30 May 2023 Location: Phoenix, Arizona Posts: 2 |
What does U3000-4B entail? Description says control module but no clue on how to approach. |
8th Jun 2023 4:45am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 |
Hi David
22nd Jan 2024 6:27pm |
My car had the electronic locking diff so it had a multiplug on the motor and the temperature sensor. They’re tucked up out of the way, however, if you’ve not got the locking diff you’ll not have them.
24th Jan 2024 12:45am |
HI David
24th Jan 2024 11:20am |
Mine is a standard diff so I just need to find my connector. Just hoping to get a steer where to look. Up around the EPB module I guess? . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
24th Jan 2024 11:25am |
The handbrake module lives on top of the subframe. The connector into that module is on the NS of the car on the top of the subframe. It’s an awkward sod to get to.
24th Jan 2024 11:50am |
amazing thank you David.
24th Jan 2024 2:28pm |
Think I found the little
25th Jan 2024 7:13pm |
update: behaving, behaving behaving then this morning faulting again on MOT test day. crap. I'm at the MOT station.....
26th Jan 2024 9:20am |
fredd589 Member Since: 24 Apr 2024 Location: Cambridge Posts: 19 |
Hey GGDR,
26th Sep 2024 2:56pm |
I removed the rear discs, cleaned up the drums, lubed it all
26th Sep 2024 4:06pm |
