![]() | Home > Technical (L322) > Electronic Handbrake Fault |
Any water or fluid ingress?
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3201 ![]() ![]() ![]() |
Not as far as I’m aware. Not been anything spilt inside it.
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1484 ![]() ![]() |
The error and flashing handbrake light are when the system detects movement, so changes in suspension height and jacking etc would effect this. You're better to chock the wheels instead of apply the parking brake.
Well that's a new one on me. All those years in a JLR dealer and I never came across that, you'd think I would have really.
I can’t get the car in the workshop or near the ramp at the moment so I slid under it and had a look at the plug on the handbrake. Everything looks ok with no obvious loose or broken wires.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Does the IID allow you to put the parking brake on/off David? |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1814 ![]() ![]() |
U2002 is either a faulty switch, or a damaged wire between the switch and EPB module |
Cheers Guys
The replacement switch I'd ordered arrived yesterday so I've just given it a go.
I finally managed to get a look under the car on the ramp tonight.
I finally managed to get time to sort the parking brake issue today. When inspecting the wiring loom there was a green blob on it. It hadn’t chaffed on anything which was my initial suspicion.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8540 ![]() ![]() ![]() |
Sorted...... |
aclr8r Member Since: 22 Oct 2013 Location: Norwich, Norfolk Posts: 23 ![]() ![]() ![]() |
Does anyone know if a low battery could also give the same fault code? The reason I ask is that after being parked up for 2 weeks, I have the same issue.
I don't think so from what Mikey posted above, unfortunately.
David. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather 2012 Range Rover 5.0 SC Autobiography in Indus Silver with Jet/Ivory Interior 2012 Range Rover 4.4 TDV8 Autobiography in Baltic Blue with Sand Interior 2013 Range Rover Sport SDV6 HSE Black Edition in Santorini Black with Ebony Interior |
