Home > Technical (L322) > Electronic Handbrake Fault
aclr8r
United Kingdom 2009 Range Rover Westminster TDV8 Santorini Black
Many thanks for your reply. Looks as though I'll be spending time under the car this weekend Sad If you don't know what you're doing - do it quickly!
Post #665525 31st May 2023 9:38am
dhallworth
I unplugged the multiplug to the rear diff, the rear diff temperature sender, and the handbrake module and then removed the rear left wheel to access the wiring loom through the wheel arch.
With those 3 things disconnected, you can get enough slack on the loom to pull enough of it into the arch to look at it. Mine was immediately apparent as there was a green blob on the wiring loom.
It's the first job I've done on this car that I've not documented with photographs I'm afraid.
Post #665545 31st May 2023 11:14am
tuchubby
United States 2008 Range Rover HSE 4.4 V8 Java Black
What does U3000-4B entail? Description says control module but no clue on how to approach.
Post #666142 8th Jun 2023 4:45am
GGDR
Hi David
I know you said you didn't get any pictures
but could you point me to the location of the connector pls
The WM doesn't show the wiring.
Reckon I have the same as you.
MOT due very soon so I need to jump on this.
 Cheers, Greg
Post #683567 22nd Jan 2024 6:27pm
dhallworth
My car had the electronic locking diff so it had a multiplug on the motor and the temperature sensor. They’re tucked up out of the way, however, if you’ve not got the locking diff you’ll not have them.
Unplugging these allowed me enough slack in the loom to pull it into the rear wheel arch with the wheel off.
It then became very apparent there was corrosion as you could see the swelling in the loom.
What fault code are you getting?
There’s someone on the Facebook group who had a similar issue recently and it turned out to be his switch.
Post #683738 24th Jan 2024 12:45am
GGDR
HI David
Thank you.
Which is switch or cable it seems.
https://www.fullfatrr.com/forum/post683447.html#683447 Cheers, Greg
Post #683759 24th Jan 2024 11:20am
GGDR
Mine is a standard diff so I just need to find my connector.
Just hoping to get a steer where to look. Up around the EPB module I guess?
. Cheers, Greg
Post #683760 24th Jan 2024 11:25am
dhallworth
The handbrake module lives on top of the subframe. The connector into that module is on the NS of the car on the top of the subframe. It’s an awkward sod to get to.
I bought a spare switch on eBay to try before going into the wiring. It’s still sitting here as a spare somewhere. Do you want me to send it to you so you can rule out the switch before going after the wiring? 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #683763 24th Jan 2024 11:50am
GGDR
amazing thank you David.
really helpful
. Cheers, Greg
Post #683775 24th Jan 2024 2:28pm
GGDR
Think I found the little Censored
No signs of damage, corrosion
Put some electrical contact grease and refitted.
Behaving so far…..
 Cheers, Greg
Post #683899 25th Jan 2024 7:13pm
GGDR
update: behaving, behaving behaving then this morning faulting again on MOT test day. crap. I'm at the MOT station.....
Replacement switch arrived yesterday, to try next but I need to roll the MOT dice first as I had a booking.
Any tips on how to get the switch out?
Many thanks Cheers, Greg
Post #683932 26th Jan 2024 9:20am
fredd589
Hey GGDR,
Did you have any luck with this? I've got the exact same error on mine!
Cheers
Post #700902 26th Sep 2024 2:56pm
GGDR
I removed the rear discs, cleaned up the drums, lubed it all
then found the connector buried in between the subframe and the boot floor, cleaned that adding electrical lube....
and it got better.
but it's still not fixed, still playing up some of the time.
I have bought a new switch in the centre console but I have not gotten around to fitting that. Cheers, Greg
Post #700904 26th Sep 2024 4:06pm
