Home > Maintenance & Mods (L322) > Mental block rear suspension!!
kevinp
I've just replaced all the rear arms and bushings and the car is sitting on axle stands in extended mode. It hasn't got the air bag or shock absorber fitted at the moment for easier access for all the bolts.
I've made a gauge, and jacked the hub so the centre is 483mm to the wheel arch so the bushes will be in their neutral position before tightening them.
I've had a mental block and can't figure out if the car needs to be in normal height mode with the full weight of the car bearing down, ie, air bag inflated to normal and shock fitted.
Please unblock my mind!!
Thanks Kev.
Post #645479 13th Oct 2022 10:43am
JayGee
Just looked at the workshop manual and it says all bolts should be tightened at normal height. I can't see how having the airbags and shocks on or off will make any difference as it won't change the angles of the suspension geometry. Brave move doing all that BTW Thumbs Up 2012 TDV8 Vogue (L322)
Post #645480 13th Oct 2022 10:48am
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
please keep me posted, i am about to do the same
i have all the bushes RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #645482 13th Oct 2022 10:58am
kevinp
Thanks JayGee.
You've confirmed I'm not going mental.
What started out at fixing some MOT advisories for perished bushes has cost me an absolute fortune!!
Post #645483 13th Oct 2022 11:08am
JayGee
Cost me a fortune for the garage to do just the rear toe links and front upper and lower arms. They said it was a nightmare cutting out seized bolts so would have been impossible for me with a jack and axle stands. The more I drive it the more I think it's money well spent. 2012 TDV8 Vogue (L322)
Post #645484 13th Oct 2022 11:12am
dhallworth
When I did mine I put it back on it's wheels at normal height with the rear shafts out which gave me plenty of room to get in there and tighten the top bolts.
Either way, as long as the height is correct so that the bushes aren't twisted after they're tightened, you'll be good Thumbs Up
Post #645488 13th Oct 2022 11:56am
kevinp
Thanks for that David. Thumbs Up
Post #645492 13th Oct 2022 12:16pm
kevinp
I was lucky mate, not one seized bolt on the front or rear. Got the rear right to do now and then I'm never going under it again!!
Post #645493 13th Oct 2022 12:20pm
dhallworth
When I did mine I removed the entire rear frame so I was lucky enough to be stripping it on the bench. The only thing that was seized was the toe control arms. The bushes that go through the bushes were absolutely seized solid. No amount of heat or anything was freeing them so I ended up having to cut them.
Would have been a nightmare of a job on the car!
Post #645494 13th Oct 2022 12:25pm
It was, I remember it well, hacksaws, cold chisels, s,b,t Big Cry .
Post #645507 13th Oct 2022 3:19pm
knares
what are these RR 2005 4.4 petrol
Post #645543 14th Oct 2022 2:42am
kevinp
Knares, have a look for PART NUMBER RGD500180. Called 'Rear toe link' on my receipt.
Post #645547 14th Oct 2022 5:57am
Ffrr-lover
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Deffo normal height as others have stated. I did this with mine, however Ive had to replace my Delphi front arms (I then went back to genuine) and have one britpart bush (each side) also in need of replacement. All under a year old.
Searching the forum afterwards I read that it should be done under load.
I appreciate that the geometry will be correct, however is not being under load when tightening definitely ok?
I was considering borrowing a ramp somewhere just to loosen and retighten all bolts as part of the rear bush re-replacements… Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2014 Audi Q7 3.0d (good riddance)
2010 L322 Autobiography 5.0 Supercharged
2011 L320 HSE 3.0 sdv6
2014 Jaguar XF-RS 5.0 supercharged
2007 BMW 535D
2005 Mini Cooper S
https://www.fullfatrr.com/forum/topic59478.html
Post #645550 14th Oct 2022 7:31am
knares
thanks RR 2005 4.4 petrol
Post #645552 14th Oct 2022 7:42am
kevinp
Thing is, FFff-lover, my thinking is that the bushes need to be 'gripped tight' at a certain position. So if I've got the suspension arms at the correct height and tighten the bolts then surely they will be in the required neutral position.
Thanks Kev.
Post #645555 14th Oct 2022 8:33am
