![]() | Home > Maintenance & Mods (L322) > Mental block rear suspension!! |
Just looked at the workshop manual and it says all bolts should be tightened at normal height. I can't see how having the airbags and shocks on or off will make any difference as it won't change the angles of the suspension geometry. Brave move doing all that BTW |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 764 ![]() ![]() ![]() |
please keep me posted, i am about to do the same
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1264 ![]() ![]() ![]() |
Thanks JayGee. You've confirmed I'm not going mental. What started out at fixing some MOT advisories for perished bushes has cost me an absolute fortune!! |
Cost me a fortune for the garage to do just the rear toe links and front upper and lower arms. They said it was a nightmare cutting out seized bolts so would have been impossible for me with a jack and axle stands. The more I drive it the more I think it's money well spent. 2012 TDV8 Vogue (L322) |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3145 ![]() ![]() ![]() |
When I did mine I put it back on it's wheels at normal height with the rear shafts out which gave me plenty of room to get in there and tighten the top bolts.
Thanks for that David. |
I was lucky mate, not one seized bolt on the front or rear. Got the rear right to do now and then I'm never going under it again!! |
When I did mine I removed the entire rear frame so I was lucky enough to be stripping it on the bench. The only thing that was seized was the toe control arms. The bushes that go through the bushes were absolutely seized solid. No amount of heat or anything was freeing them so I ended up having to cut them.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6414 ![]() ![]() |
Knares, have a look for PART NUMBER RGD500180. Called 'Rear toe link' on my receipt. |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 ![]() ![]() ![]() |
Deffo normal height as others have stated. I did this with mine, however Ive had to replace my Delphi front arms (I then went back to genuine) and have one britpart bush (each side) also in need of replacement. All under a year old.
thanks RR 2005 4.4 petrol Any spelling mistakes are the fault of spellchecker Previous MG J2, CITROEN light 15 x 2 gone unfortunately Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar |
Thing is, FFff-lover, my thinking is that the bushes need to be 'gripped tight' at a certain position. So if I've got the suspension arms at the correct height and tighten the bolts then surely they will be in the required neutral position.
