![]() | Home > My Range Rover > Help ... f***ed up! |
Chrali Member Since: 13 Apr 2017 Location: Norwich Posts: 122 ![]() ![]() ![]() |
Cheers everyone |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1368 ![]() ![]() |
You'll have to re use the top washer on the drop links if new ones weren't supplied, they need to be there and are a hardened steel for wear |
Rats .... ok thanks dingg1. I'll do it when I get a deep 18mm to tighten things up properly |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3256 ![]() ![]() ![]() |
The washer should be put back on. Also it doesn’t go on the “obvious” side behind the nut but behind the drop link. If that makes sense. On the thread before the drop link is pushed on.
Thanks weegie, I was wondering |
I agree 100% Encourage alternative fuels, use all the petrol!
I bought a Ryobi R18IW3-0 18V ONE+ mainly for getting the wheels on and off which it does very well ( final tightening with a torque wrench) but have used it on other bolts. If I was buying again I'd get one with a shorter body to make sure I could get behind things. 2012 TDV8 Vogue (L322) |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1558 ![]() ![]() |
Sorry, I burst into laughter at that. 28 deg C is just warm. Come here in summer when it is 45-49 deg C! https://www.fullfatrr.com/gallery/displayi...fullsize=1 Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
... so when changing these stabiliser rods out, you typically have the wheel off and the hub is hanging... so there is tension on the anti roll bar, and the stud at either end is angled, with nut removed.and if tapped out, wont go back in with the new one. so you have to use and axle stand. (your first one is under the subframe for safety,) so lower that, and use a second on the brake disc spacer, between the bolt holes and disc face.. to allow the car to settle, lowering a little bit at a time, then the bolt will be dead straight, and fall out. then swap out, knowing you have safety with other axle stand set much lower under the car. (or the wheel pushed under) as your 2nd stand on the disc spacer is not ideal to be gettig your head under the car/wheelarch...and refit new stabiliser, then rejack car. remove etc.
Cheers all.
