Home > My Range Rover > Help ... f***ed up!
Chrali
Cheers everyone Thumbs Up , especially Pysta Bow down
No way am I doing those rear ball joints, I'll settle for doing the front arms. Encourage alternative fuels, use all the petrol!
2012 Range Rover Vogue 4.4 TDV8
2006 Mercedes GL420 CDI
2006 Porsche Cayenne Turbo S
2006 Jeep Commander 3.0 CDI with GDE HOT Tune
1997 Nissan Patrol 4.2 GRSE
1995 Vauxhall Monterey Diamond 3.2 v6
1994 Range Rover 4.2 LSE Beluga Black, Softdash, Brooklands Body Kit - Loved it!
1993 Range Rover 4.2 LSE ended up converted to 300tdi
Post #636755 12th Jul 2022 6:11pm
dingg1
You'll have to re use the top washer on the drop links if new ones weren't supplied, they need to be there and are a hardened steel for wear Thumbs Up
Post #636756 12th Jul 2022 6:19pm
Chrali
Rats .... ok thanks dingg1. I'll do it when I get a deep 18mm to tighten things up properly Thumbs Up Encourage alternative fuels, use all the petrol!
Post #636759 12th Jul 2022 6:35pm
Weegie
The washer should be put back on. Also it doesn’t go on the “obvious” side behind the nut but behind the drop link. If that makes sense. On the thread before the drop link is pushed on.
As said above, it’s hardened steel and is there to reduce wear. John
GAP iiD BT
Post #636761 12th Jul 2022 6:45pm
Chrali
Thanks weegie, I was wondering Thumbs Up Encourage alternative fuels, use all the petrol!
Post #636766 12th Jul 2022 7:57pm
JayGee
Strongly advise for further jobs like this you invest in an good cordless impact wrench. Mechanics use these not just to save time but because the rapid hammering action frees up seized threads far more easily than simple torque. 2012 TDV8 Vogue (L322)
Post #636776 12th Jul 2022 9:08pm
Chrali
I agree 100% Encourage alternative fuels, use all the petrol!
Post #636788 12th Jul 2022 11:40pm
JayGee
I bought a Ryobi R18IW3-0 18V ONE+ mainly for getting the wheels on and off which it does very well ( final tightening with a torque wrench) but have used it on other bolts. If I was buying again I'd get one with a shorter body to make sure I could get behind things. 2012 TDV8 Vogue (L322)
Post #636795 13th Jul 2022 8:34am
p38arover
Australia
Re: Help ... f***ed up!
Chrali wrote:
I was also sweating buckets in the 28 degree heat.
Sorry, I burst into laughter at that. 28 deg C is just warm. Come here in summer when it is 45-49 deg C!
https://www.fullfatrr.com/gallery/displayi...fullsize=1 Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #636855 13th Jul 2022 10:42pm
johnboyairey
... so when changing these stabiliser rods out, you typically have the wheel off and the hub is hanging... so there is tension on the anti roll bar, and the stud at either end is angled, with nut removed.and if tapped out, wont go back in with the new one. so you have to use and axle stand. (your first one is under the subframe for safety,) so lower that, and use a second on the brake disc spacer, between the bolt holes and disc face.. to allow the car to settle, lowering a little bit at a time, then the bolt will be dead straight, and fall out. then swap out, knowing you have safety with other axle stand set much lower under the car. (or the wheel pushed under) as your 2nd stand on the disc spacer is not ideal to be gettig your head under the car/wheelarch...and refit new stabiliser, then rejack car. remove etc.
as youve found out, -leaving a car on a jack, and working on it, is like gambling your life, and families' future, on a 10p rubber seal from China.
Post #636864 14th Jul 2022 9:36am
Chrali
Cheers all.
Oh no I would never go under an unjacked car with the wheels off. I used my 3ton Sealy axle standards. The jack failed when I was trying to lift the L322 higher so I could remove the stands. It was a Sealy jack which I expected to be better than my lesser rated ancient Halfords one.
28 degrees was not fun. I wasn't using power tools to get the wheels off, lifting and lowering the FF on both sides with the standard scissor jack; so much twirling for my little office worker arms Very Happy and fighting rusty nuts. Perhaps it was the humidity and being outside, or I'm just a wimp, but hey I'm British what do I know about the sun, except more than a couple of days is too much of it Laughing
I put the hardened washers on correctly yesterday, and obviously it was so much easier this time around. I was able to line up the links on refitting without any problems by pulling on the sway bar (I assume).
I can't wait for a sensible 16 degrees Mr. Green Encourage alternative fuels, use all the petrol!
Post #637004 16th Jul 2022 1:40pm
