![]() | Home > My Range Rover > Help ... f***ed up! |
Chrali Member Since: 13 Apr 2017 Location: Norwich Posts: 122 ![]() ![]() ![]() |
Well I thought I'd replace my lower arms and drop links like everyone else does with no too much agro.
Pysta Member Since: 05 Sep 2021 Location: Bra Posts: 24 ![]() ![]() ![]() |
*most* have the possibility to put a wrench on them (14-18mm mostly) to avoid this issue
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 ![]() ![]() ![]() |
Just one of those simple jobs that turns to Rat S***. |
Indeed |
Snowy90 L322 Member Since: 24 Aug 2015 Location: Surrey Posts: 226 ![]() ![]() ![]() |
I ended up putting a reciprocating saw through the threaded part. After hours trying to free it wish i had done that to start with. |
Cheers guys,
You'd need to have both wheels off the ground to not have a ton of pressure on the link .. then it just needs a prybar (which you'll need to insert a new one too) and a whack. |
Ah ok, I've got a wheel on the ground. How much of a pry bar do I need? All I have is my breaker bar, that sounds a bit small. I'll jack up the other side and see if that improves things. Encourage alternative fuels, use all the petrol!
With both wheels off the ground it's 1-2cm you need to take care of, for which a breaker bar is ok |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1368 ![]() ![]() |
I managed ok with the opposite wheel still on the ground just using a length of wood to persuade the antiroll bar to be in the correct position
"they can be somewhat problematic " Dinng1 - That's a bit of an understatement |
grayst01 Member Since: 08 May 2022 Location: Glasgow Posts: 105 ![]() ![]() ![]() |
[quote="dingg1"]I managed ok with the opposite wheel still on the ground just using a length of wood to persuade the antiroll bar to be in the correct position
Lifting the other wheel helped me enormously, although I still had to use my jack handle to lever the bolt threads fully through. The other wheel also had swollen nuts |
Yes it absolutely can be done with the other wheel on the ground, but it's waaaay easier with both of them jacked up. When you replace the swollen nuts, make sure to clean up the threads as they might (will) mess the new nuts up too.
They can be tightened as is |
