Home > My Range Rover > Help ... f***ed up! |
Chrali Member Since: 13 Apr 2017 Location: Norwich Posts: 122 |
Cheers everyone , especially Pysta
12th Jul 2022 6:11pm |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1340 |
You'll have to re use the top washer on the drop links if new ones weren't supplied, they need to be there and are a hardened steel for wear |
12th Jul 2022 6:19pm |
Rats .... ok thanks dingg1. I'll do it when I get a deep 18mm to tighten things up properly Encourage alternative fuels, use all the petrol!
12th Jul 2022 6:35pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3233 |
The washer should be put back on. Also it doesn’t go on the “obvious” side behind the nut but behind the drop link. If that makes sense. On the thread before the drop link is pushed on.
12th Jul 2022 6:45pm |
Thanks weegie, I was wondering Encourage alternative fuels, use all the petrol!
12th Jul 2022 7:57pm |
I agree 100% Encourage alternative fuels, use all the petrol!
12th Jul 2022 11:40pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3187 |
I bought a Ryobi R18IW3-0 18V ONE+ mainly for getting the wheels on and off which it does very well ( final tightening with a torque wrench) but have used it on other bolts. If I was buying again I'd get one with a shorter body to make sure I could get behind things. 2012 TDV8 Vogue (L322) |
13th Jul 2022 8:34am |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1523 |
Sorry, I burst into laughter at that. 28 deg C is just warm. Come here in summer when it is 45-49 deg C! https://www.fullfatrr.com/gallery/displayi...fullsize=1 Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
13th Jul 2022 10:42pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
... so when changing these stabiliser rods out, you typically have the wheel off and the hub is hanging... so there is tension on the anti roll bar, and the stud at either end is angled, with nut removed.and if tapped out, wont go back in with the new one. so you have to use and axle stand. (your first one is under the subframe for safety,) so lower that, and use a second on the brake disc spacer, between the bolt holes and disc face.. to allow the car to settle, lowering a little bit at a time, then the bolt will be dead straight, and fall out. then swap out, knowing you have safety with other axle stand set much lower under the car. (or the wheel pushed under) as your 2nd stand on the disc spacer is not ideal to be gettig your head under the car/wheelarch...and refit new stabiliser, then rejack car. remove etc.
14th Jul 2022 9:36am |
Cheers all.
16th Jul 2022 1:40pm |
