Home > Technical (L405) > ABS Module fault?
Martyn
2013 Range Rover Vogue SE SDV8 Aintree Green
Just checked the passenger side, and I guess someone has been here before Laughing
 2013 FFRR Vogue SE
Post #621776 29th Jan 2022 12:18pm
Mikey
Time permitting, we normally do both sides as matter of course
If time is an issue, we rebook and repair the other side before there is an issue, if the customer agrees Thumbs Up
Post #621831 29th Jan 2022 9:25pm
that was a good call Mikey Thumbs Up ... - .- -.
Post #621833 29th Jan 2022 9:58pm
Gr4h4m
United Kingdom 2010 Range Rover Vogue SE 4.4 V8 Santorini Black
I had the same issue in my l322. It was a wiring fault /broken wire. I found a company that tested the abs module first as they are £2k As a replacement.
Great you found it
Post #621860 30th Jan 2022 11:50am
kgeddes
Reading this thread - the faults Martyn had detailed are almost exactly what I’ve got! Looks like Mikey is right about the earth connection. By any chance Martyn did your tailgate fail to open during all this?
Post #636509 9th Jul 2022 7:59pm
Martyn
Everything else was fine to be honest. 2013 FFRR Vogue SE
Post #636513 9th Jul 2022 8:06pm
kgeddes
Thanks Martyn Thumbs Up
Post #636517 9th Jul 2022 8:21pm
kgeddes
Hi again Martyn, can you remember if it was just the front part of the underwing you had to remove (5/6 screws)? Thanks
Post #636606 10th Jul 2022 8:31pm
le25dse
Norway 2014 Range Rover Vogue TDV6 Loire Blue
Thanks a lot for this thread. It led me straight to the fix. I went for an easy solution by using the bracket above as the new ground point. I can confirm that only the front half of the underwing is neccessary to remove.
2014 tdv6 (ex. 2004 td6, 1997 2.5 dse)
Post #665822 3rd Jun 2023 5:11pm
caymanblack
It's great to have someone with Mikey's expertise giving help here. Bow down overfinch modified
Post #665824 3rd Jun 2023 5:50pm
caymanblack
Checked mine today and they were all good but those black plastic clips were hard to release, so ordered some new ones,also the bottom two metal clips have rusted so need two of those. cleaned every where and put back for now.
 overfinch modified
Post #666261 9th Jun 2023 2:29pm
PC76
Shot in the dark but did this fix your issue ?
Post #696017 11th Jul 2024 7:21pm
dimsler
Canada 2013 Range Rover HSE SDV8 Santorini Black
I'd just like to thank the original poster for the excellent information. It would have taken me DAYS to figure out what was wrong, and in this case, 30min.
In my situation, I have the SDV8, so the abs module is on the drivers side. It looked in PERFECTLY good shape. Like new, well painted, and sealed. The moment I touched it with my fingers it basically broke off.
It was completely rotted inside, but completely fine on the outside.
I did the same, re-drilled new hole, M8 screw rivet, and then grounded everything. In my case since the ABS is on the drivers size, and this grounding pin not only grounds the abs, but a bunch of other things, including the headlight module? it was not just Christmas lights on the dash, but my drivers side light bulb turned off. Incase this helps anyone.
Post #701922 10th Oct 2024 3:51pm
