Home > Technical (L405) > ABS Module fault? |
Martyn Member Since: 10 Mar 2013 Location: Poole Posts: 65 |
Just checked the passenger side, and I guess someone has been here before
29th Jan 2022 1:18pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1732 |
Time permitting, we normally do both sides as matter of course
29th Jan 2022 10:25pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35179 |
that was a good call Mikey ... - .- -.
29th Jan 2022 10:58pm |
kgeddes Member Since: 11 Jan 2015 Location: UK Posts: 289 |
Reading this thread - the faults Martyn had detailed are almost exactly what I’ve got! Looks like Mikey is right about the earth connection. By any chance Martyn did your tailgate fail to open during all this? |
9th Jul 2022 8:59pm |
Everything else was fine to be honest. 2013 FFRR Vogue SE |
9th Jul 2022 9:06pm |
Thanks Martyn |
9th Jul 2022 9:21pm |
Hi again Martyn, can you remember if it was just the front part of the underwing you had to remove (5/6 screws)? Thanks |
10th Jul 2022 9:31pm |
le25dse Member Since: 15 Jan 2012 Location: Oslo Posts: 78 |
Thanks a lot for this thread. It led me straight to the fix. I went for an easy solution by using the bracket above as the new ground point. I can confirm that only the front half of the underwing is neccessary to remove.
3rd Jun 2023 6:11pm |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1123 |
It's great to have someone with Mikey's expertise giving help here. overfinch modified |
3rd Jun 2023 6:50pm |
Checked mine today and they were all good but those black plastic clips were hard to release, so ordered some new ones,also the bottom two metal clips have rusted so need two of those. cleaned every where and put back for now.
9th Jun 2023 3:29pm |
PC76 Member Since: 28 Oct 2019 Location: Home Posts: 9 |
Shot in the dark but did this fix your issue ? |
11th Jul 2024 8:21pm |
dimsler Member Since: 10 Oct 2024 Location: Toronto Posts: 1 |
I'd just like to thank the original poster for the excellent information. It would have taken me DAYS to figure out what was wrong, and in this case, 30min.
10th Oct 2024 4:51pm |
