Home > Technical (L405) > ABS Module fault?
Martyn
2013 Range Rover Vogue SE SDV8 Aintree Green
ABS Module fault?
So I jumped in the car yesterday, started it up only to be met with a full dash of lights, cycling through EBD fault, ABS fault, stability control not available, gearbox fault etc.
I plugged in the IID tool and it appears that the ABS module has died or something as it's no longer communicating with the rest of the vehicle.
Fault code list below:
L405 - Range Rover 2013
Vehicle scanned on 26-01-2022 15:49
Using IIDTool BT V4.0 B2742
ATCM-Terrain Response
U0121-00 (2F) Lost communication with ABS control module
( on 26-01-2022 15:47:51 at 75102 mi )
- Test Failed
- Test Failed This Monitoring Cycle
- Confirmed
- Test Failed Since Last Clear
U3003-62 (2F) Battery voltage - Algorithm based failure - signal compare failure
- Test Failed
- Confirmed
BCM-Body Control
( on 26-01-2022 13:17:39 at 75102 mi )
- Test Failed
- Confirmed
CCM-Cruise Control
U0121-00 (AF) Lost communication with ABS control module
( on 09-10-2026 15:21:39 at 0 mi )
- Test Failed
- Confirmed
- MIL Requested
CHCMB-Chassis Control
U300A-64 (2C) Ignition switch - Algorithm based failure - signal plausibility failure
( on 26-01-2022 13:18:32 at 75102 mi )
- Confirmed
U300A-62 (2C) Ignition switch - Algorithm based failure - signal compare failure
- Confirmed
U0100-00 (2Cool Lost communication with engine control module/powertrain control module 'A'
( on 26-01-2022 13:18:42 at 75102 mi )
- Confirmed
U0101-00 (2Cool Lost communication with transmission control module
- Confirmed
U0121-00 (2Cool Lost communication with ABS control module
- Confirmed
CHCM-Chassis Control
U0121-00 (2C) Lost communication with ABS control module
( on 26-01-2022 13:21:42 at 75102 mi )
- Confirmed
GWM-Gateway module
B13D6-87 (2F) Battery monitoring module - B - Bus signal/message failure - missing a message
( on 26-01-2022 13:17:41 at 75102 mi )
- Test Failed
- Confirmed
HCM-Headlamp
B1D65-87 (AF) Motor operation malfunction of right actuator - Bus signal/message failure - missing a message
( on 26-01-2022 13:17:43 at 75102 mi )
- Test Failed
- Confirmed
- MIL Requested
( on 26-01-2022 13:17:46 at 75102 mi )
- Test Failed
- Confirmed
- MIL Requested
IPC-Instrument Pack
- Test Failed
- Confirmed
IPMB-Camera
U0140-08 (2F) Lost communication with body control module - General failure information - bus signal/message failure
( on 09-10-2026 15:21:48 at 21 mi )
- Test Failed
- Confirmed
PBM-Parking Brake
- Test Failed
- Confirmed
- MIL Requested
PCM-Engine TDV8
U0416-68 (6C) Invalid data received from vehicle dynamics control module - Algorithm based failure - event information
( on 26-01-2022 13:18:11 at 75103 mi )
- Confirmed
- Test Not Completed This Monitoring Cycle
U0415-68 (2F) Invalid data received from ABS control module - Algorithm based failure - event information
( on 26-01-2022 13:17:44 at 75103 mi )
- Test Failed
- Confirmed
P0700-00 (2F) Transmission control system (malfunction indicator lamp request)
( on 26-01-2022 14:35:47 at 75103 mi )
- Test Failed
- Confirmed
- Test Failed
- Confirmed
PSCM-Power Steering
B1304-16 (6Cool Electronic power assisted steering system - General electrical failure - circuit voltage below threshold
( on 26-01-2022 13:18:11 at 75102 mi )
- Confirmed
U0121-31 (2F) Lost communication with ABS control module - Frequency modulation/pulse width modulation failure - no signal
( on 26-01-2022 13:17:44 at 75102 mi )
- Test Failed
- Confirmed
RCM-Airbag
U0121-00 (2B) Lost communication with ABS control module
( on 26-01-2022 13:17:45 at 75102 mi )
- Test Failed
- Confirmed
SPMA-RH Seatbelt Pretens
U0001-81 (2Cool High speed CAN communication bus - Bus signal/message failure - invalid serial data received
- Confirmed
U0001-87 (2F) High speed CAN communication bus - Bus signal/message failure - missing a message
( on 26-01-2022 13:17:48 at 75102 mi )
- Test Failed
- Confirmed
SPMB-LH Seatbelt Pretens
- Confirmed
- Test Failed
- Confirmed
TCCM-Transfer Case
( on 26-01-2022 13:17:49 at 75102 mi )
- Test Failed
- Confirmed
TCM-Transmission
U0121-63 (AF) Lost communication with ABS control module - Algorithm based failure - circuit/component protection time out
- Test Failed
- Confirmed
- MIL Requested
P279D-02 (2Cool Four wheel drive range signal circuit - General failure information - general signal failure
- Confirmed
The battery seemed a little low so I put a new one on but faults are still present and won't clear. Fuses for the ABS module appear to be fine too.
Anyone had this before?
Cheers
Martyn 2013 FFRR Vogue SE
Post #621577 27th Jan 2022 5:58pm
you told it that you have fitted a new battery?
also let it 'rest' for a bit and see whats what then.. ... - .- -.
Post #621580 27th Jan 2022 6:31pm
Martyn
Hi Stan, I did indeed.
Unfortunately resting didn't seem to do anything. 2013 FFRR Vogue SE
Post #621581 27th Jan 2022 6:33pm
Kot
Charge the battery and check all terminals are tight? 2018 SE SDV8 4.4 Byron Blue
Post #621583 27th Jan 2022 6:39pm
Martyn
I'll chuck it on the CTEK in AGM mode over night, I don't hold out much hope though as even with the CTEK in supply mode it didn't make any difference.
The terminals were tight before I replaced the battery, and were tight after replacing the battery. Secondary battery was secure too. 2013 FFRR Vogue SE
Post #621584 27th Jan 2022 6:42pm
Kot
There is also the mystical touch + and - together with the battery out, but with secondary batteries etc I dont have the Censored for that Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter 2018 SE SDV8 4.4 Byron Blue
Post #621585 27th Jan 2022 6:45pm
Dolphinboy
I had this on my 2004. All the lights went on. Went to LR and they said "oh yes sir, needs new ABS module - that'll be £1000.
"get stuffed' said I. I then took the ABS module off and saw a light corrosion on the teeth (It's badly made by BMW and sits upside down so collects water - on the 2004 anyway).
Anyhow, a quick brush of the teeth and contact spray and all good and remained so for another 60,000 miles.
Post #621617 27th Jan 2022 11:57pm
Martyn
CTEK is on the car again, no change.
I removed the airbox and removed the plug that connects to the DSC module, the pins are clean and free of corrosion, re-seated it and checked again, still no change.
I've booked the car in for proper diagnostics at a local specialist next week, then we'll see if whatever it is is covered by the warranty the car came with Rolling Eyes 2013 FFRR Vogue SE
Post #621660 28th Jan 2022 12:58pm
Mikey
Check the earth terminal in the front OS wheel arch. Known to cause ABS faults when corrosion sets in Thumbs Up
Post #621661 28th Jan 2022 1:27pm
GraemeS
Australia
Kot wrote:
There is also the mystical touch + and - together with the battery out...
mythical - it achieves nothing.
Post #621700 28th Jan 2022 8:50pm
Martyn
Oooh Mikey could be on to something here!
And after 'touching' it.
Any suggestions of how to sort this?
Leave the sheared stud as is and make a new ground point with nut / bolt? 2013 FFRR Vogue SE
Post #621751 29th Jan 2022 11:29am
TJH1985
How do you get to this, looks like something that should be cleaned up and given a generous coating of ACF50 before it gets this far? Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Previously George a 2007 MY07 Java Black VSE 3.6 TDV8
Previously a 04 MY04 Defender 90 Sad
Post #621752 29th Jan 2022 11:33am
Martyn
It's behind the front right wheel arch liner, here:
I decided to drill a new hole, clean off the paint and insert a rivnut, and then finish with a stainless bolt coated in ACF50.
Additional ACF50 sprayed over the finished item Smile
I'm pleased to know, I now have a clear dashboard!
Massive thank you to Mikey for his expert advice Smile 2013 FFRR Vogue SE
Post #621767 29th Jan 2022 12:39pm
TJH1985
I’ll add that to the summer maintenance checks.
Top work Mikey Thumbs Up Bow down Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Post #621768 29th Jan 2022 12:42pm
Mikey
Not going to say its a common issue, but its not the first one we've repaired Whistle Thumbs Up
Same earth point on the NS too, giving low coolant/bonnet open warnings Thumbs Up
Post #621769 29th Jan 2022 12:43pm
