Home > My Range Rover > My unicorn 4.4 TDV8.
Page 6 of 8 <12345678>
MartinD
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
Well, hopefully he keeps his word. I've no reason to doubt it though.
I've got a company very close who are LR specialists but more so the agricultural rather than Range Rover me thinks.
Not aware of any other nearby specialists but I'll have a wee search. 2011 4.4 TDV8 Vogue SE - 'Black Betty'
2000 4.0 P38 HSE - 'Green Goblin' - Gone.
Audi..Mini..BMW..
Post #611212 31st Oct 2021 8:10pm
MartinD
So, just back from having the car scanned.
It had 31 error codes when he first plugged it in so cleared them and then drove 2 miles and scanned again:
Speed Control Module
U0421-81 Invalid data received from ride level control module
Powertrain Control Module
P040D-00 Exhaust gas recirculation temperature sensor A - circuit high
Ride Level Control Module
C1A36-01 Exhaust Valve
He's going to price up the required parts and pending more investigation, will order and replace.
In the meantime, can anyone tell me if any of these are serious or perhaps indicators of a problem?
Want to be going to the dealer/trader with the best information possible! 2011 4.4 TDV8 Vogue SE - 'Black Betty'
Audi..Mini..BMW..
Post #611394 2nd Nov 2021 4:29pm
JayGee
P040D-00 Exhaust gas recirculation temperature sensor A - circuit high - this is a common fault / sensor fail. It's a tricky to get at sensor but a lot of people seem to just run fine with it in this state. I had mine fixed but not noticed any difference. 2012 TDV8 Vogue (L322)
Post #611398 2nd Nov 2021 4:57pm
MartinD
I've done quite a bit of searching about it on here and other places. Seems to be a 13+page thread on it but can't see any definitive info. Last thing I'd want is to ignore it and find it has an adverse affect on something else down the line. 2011 4.4 TDV8 Vogue SE - 'Black Betty'
Audi..Mini..BMW..
Post #611400 2nd Nov 2021 5:06pm
Sonearly
United Kingdom 2017 Range Rover Autobiography SDV8 Santorini Black
I would get it done or you will be forever wondering, if the dealer has said he will cover costs why not, the sensor is around £150 and fitted total price around £350. It’s a simple job but a pig to do due to access. I should imagine the other two faults are related and may as simple as the exhaust valve on compressor. It may just be blocked. I sure more peeps will tell you more and even have definitely answer.
Post #611403 2nd Nov 2021 5:41pm
JayGee
Maybe worth starting a new thread in the appropriate subforum as well Wink 2012 TDV8 Vogue (L322)
Post #611404 2nd Nov 2021 5:43pm
MartinD
Well, had the health check this morning.
Given it had an MOT last month with no advisories. I'm somewhat surprised at the state of the brake lines and brake shield at OSF - which is catching in the disk. That explains the Squeeking and Grinding,
Compressor does need replaced.
Will see what the dealer says. 2011 4.4 TDV8 Vogue SE - 'Black Betty'
Audi..Mini..BMW..
Post #612783 16th Nov 2021 12:23pm
DrRob
Get the P040D done at dealers cost then at least it's been done and won't cause any potential issues if DPF ever went to red for an unrelated reason. That's my 2p anyway!
Taken me a while to get my "spot on" and still bits crop up e.g. stuck rear caliper Big Cry Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #612789 16th Nov 2021 12:59pm
JayGee
If it's just brakes and a compressor you have done well! 2012 TDV8 Vogue (L322)
Post #612799 16th Nov 2021 3:03pm
MartinD
So, quote back is £1300 odd.
Dealer has suggested they pay half but asked me what I want to do.
I like the guy and he seems honest enough to me.. and I'm not an asshole.. but I genuinely don't think I should have to pay any of it really. Was gonna suggest 75%/15% split.
What do you think? 2011 4.4 TDV8 Vogue SE - 'Black Betty'
Audi..Mini..BMW..
Post #612905 17th Nov 2021 3:24pm
mjdronfield
75 / 15 split isn’t gonna work 🤔
If you don’t feel you need to pay any, ask them to explain why you should…..
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #612908 17th Nov 2021 3:40pm
mjdronfield
Think the brake shields are about £70 and hub needs to come off, unless you cut the new one to slide it in.
I think compressors tend to be £700 ish fitted… and I paid £350 ish for brake pipes in January from a specialist if it helps you work the maths out.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #612910 17th Nov 2021 3:44pm
JayGee
Take the 50/50 and move on if these are the only things wrong with it. The dealer could insist your only other option is to return the car for a full refund as they now know there are only a few issues they could fix themselves and then sell it to another customer for more money. 2012 TDV8 Vogue (L322)
Post #612911 17th Nov 2021 3:45pm
JayGee
Compressors are about £350 and an easy and quick DIY job. 2012 TDV8 Vogue (L322)
Post #612912 17th Nov 2021 3:47pm
MartinD
Yeah, I meant 75/25 haha.
The parts costs aren't too bad - the labour is £75/hour.
The compressor doesn't appear to be an entirely new unit.. "KIT - COMPRESSOR OVERHAUL" and that's £414.
I hear what folk say about 50/50 however, I had planned to do a complete fluid change and some other preventative work anyway which would be near the 1k mark on its own. 2011 4.4 TDV8 Vogue SE - 'Black Betty'
Audi..Mini..BMW..
Post #612915 17th Nov 2021 3:58pm
