Home > Maintenance & Mods (L322) > 4.4 TDV8 Remap/DPF Removal
Page 2 of 3 <123>
kevinp
Did you have as much as this Mike?
Post #605176 30th Aug 2021 1:44pm
Baltic Blue
Not quite that bad (79k miles), but certainly revs much freer now ,absolutely no hesitation pulling away when I boot it, gets past 2,500 rpm in a flash, with absolutely not a trace of smoke.
I did a 100+ mile each way motorway trip last week and trip computer said 34.7 mpg. for complete journey.
Very pleased.
Post #605178 30th Aug 2021 1:59pm
kevinp
Mines still not happy with hard acceleration from a complete standstill. Slight delay then it's tries to break my neck!! I have to clean the MAP sensor every few months and it seems a bit smoother.
Post #605181 30th Aug 2021 2:22pm
JayGee
That sudden shock loading not good for the gearbox at all.
Post #605196 30th Aug 2021 5:13pm
Even less good for the drive shafts/CV's... Replace quite a few where owners turn right or left and 100% "POWER" and bang!!! Big Cry Whistle
Post #605227 31st Aug 2021 12:16am
kevinp
Gonna have to get it booked in with you Craig and let you do your magic. Not bothered about more power, just want to make it smoother.
Post #605229 31st Aug 2021 4:22am
Post #605242 31st Aug 2021 10:35am
kooky_guy
United Kingdom 2010 Range Rover Vogue SE TDV8 Stornoway Grey
Baltic Blue wrote:
I have just cleaned out the plenum chamber and throttle body on mine and the difference is staggering, costs nothing and as good as any remap.
Mike.
I was thinking mine could probably benefit from this. Was is straightforward to do? 2010 4.4 TDV8 Vogue SE
Post #605329 1st Sep 2021 3:58pm
DrRob
There is a DIY how to on here somewhere. Will find it for you Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #605351 1st Sep 2021 6:52pm
ffrr14
Australia 2011 Range Rover Autobiography TDV8 Orkney Grey
I have had mine mapped out and tuned up, I also have the latest ZF tune and strategies to go with it. This has improved the drivability to another level(it was great before mind you). Very Happy SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New Toy: Unimog U1550L/37
New : G350D
Post #605370 1st Sep 2021 10:50pm
GraemeS
Australia
Was your gearbox update a LR version or was it from ZF? When my 3.0 D4's gbox was rebuilt by a ZF authorised repairer the updated ZF firmware was much better than the LR version in reduced TC slip.
Post #605381 2nd Sep 2021 8:48am
ffrr14
I am not sure to be honest, I am told this is the latest firmware for the 8 speed ZF. The gear change sort of glides up and down even wth paddle shift ..love it.
I do have a slop in the rear which I feel when I am bit enthusiastic with my driving Smile Any idea what that could be? As far as I can tell this car has never been off road so maybe a cv or the like SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New : G350D
Post #605409 2nd Sep 2021 1:20pm
GraemeS
Australia
Thanks. I had mine's gbox s/w updated to the latest (LR) level some time ago and whilst it was a significant improvement there's room for more. However at least the TC stays locked at slower speeds in 3rd than it did especially if I wait a couple of seconds between releasing brakes and touching the accelerator and I can make it stay locked at even lower revs by changing to command-shift mode using the upshift paddle while slowing into a slow street corner. Engine revs were reduced on quicker take-offs from well over 2000 rpm to around 1800 rpm but there's no need for even those revs with this engine's torque.
Wear of the rear suspension bushes doesn't only occur off the black-top.
Post #605451 2nd Sep 2021 9:54pm
ffrr14
The zf didn't feel matched after the engine tune which now does. It feels like it has benefited from the latest l405 developments.
Part Part number
Assembly (F112) Unknown
Assembly (F113) BH42-7000-AG
Calibration (F124) BH42-7J105-HK
Hardware (F111) BH42-14C247-HB = BH42-14C247-HA
Serial 101023700A002163
Signal (F120) BH42-14C389-HB
Strategy (F188) BH42-7J104-HF
The suspension bushing is solid all around (rear cvd need replacing). The slop is more in the driveline, feels like a coupling. Also it is not noticeable on gentle take off. SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New : G350D
Post #605456 2nd Sep 2021 11:03pm
GraemeS
Australia
I just found this thread again and can confirm my gearbox s/w is the same as yours ffrr14.
Post #645755 16th Oct 2022 8:15am
Page 2 of 3 <123>
