![]() | Home > Maintenance & Mods (L322) > 4.4 TDV8 Remap/DPF Removal |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1264 ![]() ![]() ![]() |
Did you have as much as this Mike?
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
Not quite that bad (79k miles), but certainly revs much freer now ,absolutely no hesitation pulling away when I boot it, gets past 2,500 rpm in a flash, with absolutely not a trace of smoke.
That sudden shock loading not good for the gearbox at all. |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 ![]() ![]() ![]() |
Even less good for the drive shafts/CV's... Replace quite a few where owners turn right or left and 100% "POWER" and bang!!! |
Gonna have to get it booked in with you Craig and let you do your magic. Not bothered about more power, just want to make it smoother. |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 ![]() ![]() ![]() |
I was thinking mine could probably benefit from this. Was is straightforward to do? 2010 4.4 TDV8 Vogue SE |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4314 ![]() ![]() ![]() |
There is a DIY how to on here somewhere. Will find it for you |
ffrr14 Member Since: 21 Apr 2021 Location: Sydney Posts: 187 ![]() ![]() ![]() |
I have had mine mapped out and tuned up, I also have the latest ZF tune and strategies to go with it. This has improved the drivability to another level(it was great before mind you). |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2560 ![]() ![]() ![]() |
Was your gearbox update a LR version or was it from ZF? When my 3.0 D4's gbox was rebuilt by a ZF authorised repairer the updated ZF firmware was much better than the LR version in reduced TC slip. |
I am not sure to be honest, I am told this is the latest firmware for the 8 speed ZF. The gear change sort of glides up and down even wth paddle shift ..love it.
Thanks. I had mine's gbox s/w updated to the latest (LR) level some time ago and whilst it was a significant improvement there's room for more. However at least the TC stays locked at slower speeds in 3rd than it did especially if I wait a couple of seconds between releasing brakes and touching the accelerator and I can make it stay locked at even lower revs by changing to command-shift mode using the upshift paddle while slowing into a slow street corner. Engine revs were reduced on quicker take-offs from well over 2000 rpm to around 1800 rpm but there's no need for even those revs with this engine's torque.
The zf didn't feel matched after the engine tune which now does. It feels like it has benefited from the latest l405 developments.
I just found this thread again and can confirm my gearbox s/w is the same as yours ffrr14. |
