Home > Maintenance & Mods (L322) > 4.4 TDV8 Remap/DPF Removal |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1206 |
Did you have as much as this Mike?
30th Aug 2021 12:44pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3766 |
Not quite that bad (79k miles), but certainly revs much freer now ,absolutely no hesitation pulling away when I boot it, gets past 2,500 rpm in a flash, with absolutely not a trace of smoke.
30th Aug 2021 12:59pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3206 |
That sudden shock loading not good for the gearbox at all. |
30th Aug 2021 4:13pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Even less good for the drive shafts/CV's... Replace quite a few where owners turn right or left and 100% "POWER" and bang!!! |
30th Aug 2021 11:16pm |
Gonna have to get it booked in with you Craig and let you do your magic. Not bothered about more power, just want to make it smoother. |
31st Aug 2021 3:22am |
31st Aug 2021 9:35am |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 385 |
I was thinking mine could probably benefit from this. Was is straightforward to do? 2010 4.4 TDV8 Vogue SE |
1st Sep 2021 2:58pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
There is a DIY how to on here somewhere. Will find it for you Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
1st Sep 2021 5:52pm |
ffrr14 Member Since: 21 Apr 2021 Location: Sydney Posts: 187 |
I have had mine mapped out and tuned up, I also have the latest ZF tune and strategies to go with it. This has improved the drivability to another level(it was great before mind you). SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
1st Sep 2021 9:50pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2475 |
Was your gearbox update a LR version or was it from ZF? When my 3.0 D4's gbox was rebuilt by a ZF authorised repairer the updated ZF firmware was much better than the LR version in reduced TC slip. |
2nd Sep 2021 7:48am |
I am not sure to be honest, I am told this is the latest firmware for the 8 speed ZF. The gear change sort of glides up and down even wth paddle shift ..love it.
2nd Sep 2021 12:20pm |
Thanks. I had mine's gbox s/w updated to the latest (LR) level some time ago and whilst it was a significant improvement there's room for more. However at least the TC stays locked at slower speeds in 3rd than it did especially if I wait a couple of seconds between releasing brakes and touching the accelerator and I can make it stay locked at even lower revs by changing to command-shift mode using the upshift paddle while slowing into a slow street corner. Engine revs were reduced on quicker take-offs from well over 2000 rpm to around 1800 rpm but there's no need for even those revs with this engine's torque.
2nd Sep 2021 8:54pm |
The zf didn't feel matched after the engine tune which now does. It feels like it has benefited from the latest l405 developments.
2nd Sep 2021 10:03pm |
I just found this thread again and can confirm my gearbox s/w is the same as yours ffrr14. |
16th Oct 2022 7:15am |
