![]() | Home > In Car Electronics (L322) > 2008 range rover - radio system problem |
Brash1979 Member Since: 14 Aug 2021 Location: Widnes Posts: 3 ![]() ![]() ![]() |
Could anyone help with this in anyway?
RichM63 Member Since: 10 Jul 2019 Location: Brittany Posts: 249 ![]() ![]() ![]() |
I've had the same problem for 2 years.
Rich,
Nope;
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 780 ![]() ![]() ![]() |
It sounds very like you have moisture ingress at the rear left wheel arch which is affecting the electonic controls housed in the back left side of the boot. I had intermittent issues with radio and sat-nav for several years before opting to replace the head unit, which didn't sort the problem. The culprit turned-out to be the amplifier in the boot cavity. This was a symptom of a bigger issue which has now become visible corrosion at the rear of the wheel arch. The older I get, the more I realise that people confuse wrinkles for wisdom |
lucasvrooij Member Since: 10 Feb 2021 Location: Breda Posts: 5 ![]() ![]() ![]() |
I’m having the same problem and wonder if someone managed to sort this?
JonnyCJ Member Since: 12 Mar 2024 Location: Wirral Posts: 157 ![]() ![]() ![]() |
Try pressing CD or radio, then switching off with the main audio button and then switching on again. See if the CD/radio now works.
Thanks for thinking with Jonny. Gave that a go but no luck.
MariusRR Member Since: 19 Mar 2013 Location: Oslo Posts: 102 ![]() ![]() ![]() |
Was anyone here able to sort this out? |
Barmybrummie Member Since: 03 Apr 2021 Location: Somewhere in the valleys Posts: 752 ![]() ![]() ![]() |
Have you tried the battery reset option? Remove both battery leads leave a few minutes then touch them together, refit battery leads and see if that helps. |
