Home > In Car Electronics (L322) > 2008 range rover - radio system problem
Brash1979
United Kingdom 2008 Range Rover Vogue SE TDV8 Barolo Black
Hi all, just just wondering if anyone could help me, I'm experiencing a problem with my media system on my car, here is what's happening.
On my audio screen which has the touch screen buttons for radio, cd, aux and TV it is stuck on radio, the radio is working but all the preset buttons don't work, to change channel you have to manually enter the station.
The cd, aux and tv functions don't seem to work at all, I've been into the onboard diagnostics to check the video input and they seem to be working when testing but once I go back to the main audio screen I can still not choose different options.
The sat nav seems to work fine, I have disconnected the Bluetooth and put a loop in this as this was not working, I've replaced the TV tuner but still nothing, can anyone help in anyway at all.
I would be grateful, thanks all
Post #603762 14th Aug 2021 12:54pm
Brash1979
Could anyone help with this in anyway?
It's so frustrating, I am hoping that someone has experienced this in the past and found a solution.
Thanks all
Post #603851 15th Aug 2021 4:22pm
RichM63
France 2006 Range Rover Vogue TDV8 Stornoway Grey
I've had the same problem for 2 years.
I don't believe that anyone anywhere knows of a solution.
Best, Rich L322 3.6 TDV8 Vogue. 07MY
ML 320 7 Seat full leather etc. (The Black Pearl) Wink
Post #603860 15th Aug 2021 6:14pm
Brash1979
Rich,
Did you not manage to sort it then? It's so frustrating.
Post #603929 16th Aug 2021 3:36pm
RichM63
Nope;
Removed the BT module, changed the Logig7 amp, rebuilt the MOST cable loop.
Tried every combination of the components that is possible.
Removed and replaced all fuses front and rear and the 4 relays in the rear panel.
and still have the same problems that you describe.
On starting the car I have to do the press 5 seconds on the screen routine and then enter the code 134679 code and then the MOST Test and Reboot MOST Loop for the trip meter etc.
But still the thing remains stuck on Radio with no CD etc and only the volume controls on the steering wheel work
It really is a useless system (note politeness!)
Cheers, Rich L322 3.6 TDV8 Vogue. 07MY
Post #603933 16th Aug 2021 3:52pm
JMC
Scotland 2012 Range Rover Westminster TDV8 Orkney Grey
It sounds very like you have moisture ingress at the rear left wheel arch which is affecting the electonic controls housed in the back left side of the boot. I had intermittent issues with radio and sat-nav for several years before opting to replace the head unit, which didn't sort the problem. The culprit turned-out to be the amplifier in the boot cavity. This was a symptom of a bigger issue which has now become visible corrosion at the rear of the wheel arch. The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #604368 21st Aug 2021 4:08pm
lucasvrooij
Netherlands 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
I’m having the same problem and wonder if someone managed to sort this?
Stuck on radio, AUX/Cd not working and only volume controls on the steering wheel works.
Post #712778 25th Feb 2025 6:12pm
JonnyCJ
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Sumatra Black
Try pressing CD or radio, then switching off with the main audio button and then switching on again. See if the CD/radio now works.
Probably won’t, however this is the method for using DAB when you switch the old non functioning DAB module for a DAB+ module.
Worth a try !
Post #712897 26th Feb 2025 9:48pm
lucasvrooij
Thanks for thinking with Jonny. Gave that a go but no luck.
Very curious what the two ther forum members did to solve this. Sent them a pm but no reply yet.
Post #712914 27th Feb 2025 8:08am
MariusRR
Norway 2003 Range Rover Vogue 4.4 V8 Oslo Blue
Was anyone here able to sort this out?
Post #716606 22nd Apr 2025 10:06pm
Barmybrummie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Have you tried the battery reset option? Remove both battery leads leave a few minutes then touch them together, refit battery leads and see if that helps.
Post #716609 22nd Apr 2025 10:37pm
