Home > General > What Did You Do In Your Full Fat Today
Page 5 of 382 <123 456 ... 380381382>
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
Fox wrote:
Vogue wrote:
Thumbs Up ha ha, yes been there done that, very good use of a RR to get a baby to sleep Thumbs Up
Didn't work for us, it was too smooth!
Had to use the Defender, getting bounced about all over the place did the trick. Laughing
Trist78 wrote:
Why is it a dealer cant even clean a car without scratching it ???
Because the plum doing it doesn't care , it's a low paid basic job washing some posh nob's car. (IMO)
Yup my IIa with the Jag lump in and side exit exhaust had the same effect Thumbs Up Its in the blood Wink
As for what I did with my FFRR.. trod on the FFRR OE mats that are currently in the Pathfinder Smile
and moved the knackered steering wheel motor / paperweight across the computer desk. 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #65780 25th May 2011 9:21pm
dan_uk_1984
Trist78 wrote:
The FF came back from the steelers with the diagnosis of the two breathers requiring a change !!!
I was bang on thanks to the forum!
The Censored decided to wash it as well!! I went mad Ive only started detailing the rangie and now it has more swirl marks!!!
Make sure they change the four breathers, they won't want to do the lower two, but they will need doing...
Post #65782 25th May 2011 9:22pm
Trist78
2004 Range Rover Vogue 4.4 V8 Java Black
Any reason why they wont want to Dan?
Post #65791 25th May 2011 9:39pm
PITA to change and would be hard for you to check.
Took the dog out in mine today after changing the rear discs and pads.
Post #65793 25th May 2011 9:41pm
dan_uk_1984
Because they are REALLY difficult. The one off the cyclone is hard, but the one on the bottom of the PCV valve itself is nearly impossible. Some garages insist on taking the inlet manifold off to get enough room, and that's not a road you want to go down!
Post #65794 25th May 2011 9:42pm
Trist78
I was dreading that you were going to say that !!
Have you done it yourself Dan!
Is it just hard to reach !!
Post #65795 25th May 2011 10:08pm
dan_uk_1984
Nope, what sort of crazy do you think I am!?
I've done the top two myself and they are a peice of cake. I need to do the lower two, which I will use my cheap local mechanic. But not this one:
http://www.fullfatrr.com/forum/topic1786.html
So my last forray into getting this changed didn't work out so well! I ended up having to replace the whole valve and everything :'(
Post #65799 25th May 2011 10:23pm
dan_uk_1984
Hang on a minute - According to your profile you have a TD6! You don't have a PCV system!
Post #65801 25th May 2011 10:31pm
Trist78
Just thought you were the hands on person Dan !!
Well I got to make sure the dealer gets everything done on the breather hoses then !!
What do folks here do with regards to servicing the FF!!
Do many DIY or does the garages have to do it!!
Ive been hands on with most of the vehicles I have had so was thinking of doing most of the servicing myself! Well thinking about it !!
At least I know it be done !!
Are there anything I got to watch out for !!!
Post #65803 25th May 2011 10:37pm
DMRR
Looked dejectedly at the "service due" message on the TFT Sad
It's booked in for next Wednesday - so that will be £450 for the service, £400 for the brakes, £1200 for the tyres no doubt Sad Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #65804 25th May 2011 10:42pm
dan_uk_1984
I do most things myself - just some jobs are worth paying someone else to do if you know what I mean!
There is nothing on the service schedule that you cant DIY. With the exception of the gearbox oil which must be done every 50-60,000 (regardless of if the garage tell you they are "sealed for life" - that is the life of the warranty)
Post #65806 25th May 2011 10:46pm
Trist78
Yeap got the gearbox high up the ist to be done !!
As I have mention before the car has only done 54k owned by father and daughter.
The father had it serviced regardless form what I have read on the receipt and the daughter just drove it !!!
So I was told by the dealer that it was serviced 3k ago or at least in nov last year!!
But im not convinced the oil is worse than the td5 when Ive changed after about 10k!!!
Brake fluid is pretty much contaminated and the antifreeze well i think its just water now. I ve been inform that on these it should be a 50/50 mix!
What do peps genereally put on after market bits ie, oil filters .. or after market ones!!
I always did put genuine on the td5 but on the 200 abit of a mix and then ended up putting genuine as most after market don last as long as the genuine !!
Post #65808 25th May 2011 11:00pm
dan_uk_1984
Personally I tend not to use genuine, I've never found LR parts particularly good quality and got fed up with every time I bought an oil filter it was blatantly made by a different manufacturer - usually whichever would knock them out cheapest I guess.
For air filters I would stick with genuine, but oil filter I go with K&N these days as they are the same price as LR. For brake pads I go for cheap ones as they tend to be softer it means you go through pads rather than discs... Fluids I usually buy whatever is on offer, I use Carlube oil but change it twice as often (summer and winter grade) I've never changed anti-freeze, something always bursts and dumps the coolant yearly anyway!
Post #65810 25th May 2011 11:05pm
Trist78
Thanks for that Dan
Ill start looking into it!!
Where did you buy your k&n oil filters from egay??
Post #65815 25th May 2011 11:17pm
dan_uk_1984
Yup, I get everything off The Bay!
Post #65817 25th May 2011 11:28pm
