Home > General > What Did You Do In Your Full Fat Today |
Make sure they change the four breathers, they won't want to do the lower two, but they will need doing... |
25th May 2011 8:22pm |
Trist78 Member Since: 07 May 2011 Location: Worcester Posts: 78 |
Any reason why they wont want to Dan? |
25th May 2011 8:39pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
PITA to change and would be hard for you to check.
25th May 2011 8:41pm |
Because they are REALLY difficult. The one off the cyclone is hard, but the one on the bottom of the PCV valve itself is nearly impossible. Some garages insist on taking the inlet manifold off to get enough room, and that's not a road you want to go down! |
25th May 2011 8:42pm |
I was dreading that you were going to say that !! Have you done it yourself Dan! Is it just hard to reach !! |
25th May 2011 9:08pm |
Nope, what sort of crazy do you think I am!?
25th May 2011 9:23pm |
Hang on a minute - According to your profile you have a TD6! You don't have a PCV system! |
25th May 2011 9:31pm |
Just thought you were the hands on person Dan !! Well I got to make sure the dealer gets everything done on the breather hoses then !! What do folks here do with regards to servicing the FF!! Do many DIY or does the garages have to do it!! Ive been hands on with most of the vehicles I have had so was thinking of doing most of the servicing myself! Well thinking about it !! At least I know it be done !! Are there anything I got to watch out for !!! |
25th May 2011 9:37pm |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
Looked dejectedly at the "service due" message on the TFT
25th May 2011 9:42pm |
I do most things myself - just some jobs are worth paying someone else to do if you know what I mean!
25th May 2011 9:46pm |
Yeap got the gearbox high up the ist to be done !! As I have mention before the car has only done 54k owned by father and daughter. The father had it serviced regardless form what I have read on the receipt and the daughter just drove it !!! So I was told by the dealer that it was serviced 3k ago or at least in nov last year!! But im not convinced the oil is worse than the td5 when Ive changed after about 10k!!! Brake fluid is pretty much contaminated and the antifreeze well i think its just water now. I ve been inform that on these it should be a 50/50 mix! What do peps genereally put on after market bits ie, oil filters .. or after market ones!! I always did put genuine on the td5 but on the 200 abit of a mix and then ended up putting genuine as most after market don last as long as the genuine !! |
25th May 2011 10:00pm |
Personally I tend not to use genuine, I've never found LR parts particularly good quality and got fed up with every time I bought an oil filter it was blatantly made by a different manufacturer - usually whichever would knock them out cheapest I guess.
25th May 2011 10:05pm |
Thanks for that Dan Ill start looking into it!! Where did you buy your k&n oil filters from egay?? |
25th May 2011 10:17pm |
Yup, I get everything off The Bay! |
25th May 2011 10:28pm |
