Home > General > What Did You Do In Your Full Fat Today
Page 348 of 382 <123 ... 347348349 ... 380381382>
Spence
Visited Perthshire to see family, thought I’d take a route less travelled. I mean, why not!!
 - L322 TDV8 4.4 Westminister
- BMW G01 X3
- BMW R1200 GSA
Gone but not forgotten
- Series III Lightweight (1977, Ex Saudi Military)
Post #624657 24th Feb 2022 8:35pm
Soldierpmr
Wales 2007 Range Rover Vogue TDV8 Zermatt Silver
Fitted a new quilted boot liner.
Post #624729 25th Feb 2022 3:43pm
Slow progress
Collected it from the mechanics, two new rear brake callipers, PAS fluid change, and identification of the parking sensor that’s not working.
Also fitted the boot tray, dog guard and divider.
Discovered the inevitable rear light issues, one full of condensation despite the small hole drilled in it, the other with a big crack in the outer plastic. So a pair to order after it gets back from the Bodyshop in April.
Post #624809 26th Feb 2022 3:33pm
vs322
Greece 2004 Range Rover HSE 4.4 V8 Java Black
Fitted the improved LED reversing light bulbs. Much brighter indeed Thumbs Up
Post #624860 26th Feb 2022 9:15pm
mrtidy
United Kingdom 2009 Range Rover Vogue SE TDV8 Zermatt Silver
Fitted a new reversing camera,bought from powerfuluk and works a treat,only £110 against nearly £400 from land rover,also fitted a new non return valve (actually a non return valve off a fish tank air pump) to my rear washers while the tailgate trim was off ,the washer fluid used to take ages to come through so well worth doing,a productive day. Thumbs Up 2009 Vogue SE Zermatt silver
Post #624879 27th Feb 2022 12:52am
Full-fat-Lance
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Orkney Grey
Fitted a smoked rear brake light (makes a massive difference to the look), fitted interior leds all round and replaced the bit of trim at the rear of the centre console which has the flap to hide the av/12v sockets as the flap had broken
Before…
And after…
Post #625447 5th Mar 2022 7:32pm
Slow progress
Removed both front windows blue tinted film in about 5mins…..spent the next 3hrs removing the glue!
Discovered the window closing issue on front passenger side so another job to add to the list! L322 TD6 2003
Epsom Green- the dogs car which has worked it’s way into being the family car 😮
Post #625547 6th Mar 2022 8:27pm
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Supplies to repair fence after recent storm.
 Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #625688 8th Mar 2022 3:04pm
JMC
Did my Jeremy Clarkson impersonation, climbing up a hill to photograph some USAF low flyers in new F35 Lightning's from Lakenheath
 The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #625927 11th Mar 2022 12:01am
Huttopia
Drove to Twickenham in the P38 yesterday to watch the rugby. No shortage of RRs funnily enough, at least one broken down on the M40.
Post #626084 13th Mar 2022 5:34pm
JayGee
1000+ miles London to Glencoe and back 2012 TDV8 Vogue (L322)
Post #626150 14th Mar 2022 3:23pm
l3224.2sc
United Kingdom 2007 Range Rover Autobiography 4.2 SC V8 Stornoway Grey
Went to pick up my Westfalia tow bar with farmers hitch. Lovely run out. Just need to find 2 or 3 blokes called Jack to lift it into place. current l322 4.2sc, p38a 4.0 hse, x350 xjr, x308 xjr, x308 daimler super8, saab 93 convertible and a Transit. Most bases covered.
Post #626183 14th Mar 2022 10:13pm
JayGee
Replaced the headlight washer pump so now have working headlight washers! ( never worked since I had it ) Had good look underneath and around the suspension and it doesn't look in too bad a shape for a 10 yr old British car.... 2012 TDV8 Vogue (L322)
Post #626487 19th Mar 2022 1:24pm
Andy S
United Kingdom 2015 Range Rover Vogue SE SDV8 Aintree Green
Cleaned the interior after a trip to the Alps, so thats clean carpets, leather cleaned and leather balm applied and all hard surfaces cleaned and dusted. Smells much better now….
Post #626491 19th Mar 2022 3:27pm
Chrali
I cleaned my map and maf sensors. Happily the map sensor was pretty clean, so I assume my trusted garage cleaned it when they changed the plenum. Also had to refit my drivers side mirror cap and t-cut the large scuff off from the idiot whose van smacked my car with his van and knocked it loose. Also had to grease the tyre valve stems as the metal valve caps had seized on. Encourage alternative fuels, use all the petrol!
2012 Range Rover Vogue 4.4 TDV8
2006 Mercedes GL420 CDI
2006 Porsche Cayenne Turbo S
2006 Jeep Commander 3.0 CDI with GDE HOT Tune
1997 Nissan Patrol 4.2 GRSE
1995 Vauxhall Monterey Diamond 3.2 v6
1994 Range Rover 4.2 LSE Beluga Black, Softdash, Brooklands Body Kit - Loved it!
1993 Range Rover 4.2 LSE ended up converted to 300tdi
Post #626523 20th Mar 2022 11:59am
