![]() | Home > Maintenance & Mods (L322) > 2010+ Front wiper arm removal |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8368 ![]() ![]() ![]() |
Copper slip is not recommended to be used on any alloy, add another metal to the alloy wipers and water and you will get galvanic corrosion Same reason you don't use it on alloy brake callipers... ![]() I now have permission from the boss to use Y.O.L.O. Enjoy life __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
Goldstar Member Since: 04 Dec 2021 Location: Reading Posts: 117 ![]() ![]() |
Ah OK thanks, mine's a facelift and looks like a single casting ie no other piece. You can really see the galvanic corrosion in the 2nd pic
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 775 ![]() ![]() ![]() |
Can't speak for earlier incarnations (TD6), but I can confirm that all TDV8's share the same arms. The older I get, the more I realise that people confuse wrinkles for wisdom ![]() |
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 282 ![]() ![]() ![]() |
Corrosion Block Grease may be a good alternative: https://www.killerbrands.co.uk/products/co...e-454g-tub TDV8 4.4 2012 |
I have managed to source a pair from ebay. I'll see how they are when they arrive but as a minimum I will have a new plastic aero part which is the bit that is broken on my current arm
oggy Member Since: 09 Sep 2020 Location: padstow cornwall Posts: 395 ![]() ![]() ![]() |
yes you are right haylands do not use copper slip I will amend |
