Home > Maintenance & Mods (L322) > 2010+ Front wiper arm removal
oggy wrote:
and loads of copper slip when putting back
Copper slip is not recommended to be used on any alloy, add another metal to the alloy wipers and water and you will get galvanic corrosion
Same reason you don't use it on alloy brake callipers... Thumbs Up Pete
Post #652379 2nd Jan 2023 9:08pm
dhallworth
The arms did change over the production of the car.
The earlier cars had an aluminium piece on the spigot the arms mount to under the arm, the later cars don’t.
I changed the arms on mine last year and all the arms supersede to the newer type where you don’t need the spacer on the arm.
Post #652384 2nd Jan 2023 9:49pm
Goldstar
2011 Range Rover Autobiography TDV8 Stornoway Grey
Ah OK thanks, mine's a facelift and looks like a single casting ie no other piece. You can really see the galvanic corrosion in the 2nd pic
Thanks for your help
 Dec 2021- 2010 Facelift TDV8 4.4 AB in Stornoway Grey.
Post #652392 2nd Jan 2023 10:19pm
JMC
Scotland 2012 Range Rover Westminster TDV8 Orkney Grey
Goldstar wrote:
Thanks for the reply, I have the arm off, courtesy of a 2 arm puller (the noise was a bit of a shock) so just need to know if thee arms changed during the production run. I somehow doubt it but just wanted to check.Cheers
Can't speak for earlier incarnations (TD6), but I can confirm that all TDV8's share the same arms. The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #652411 3rd Jan 2023 9:44am
Ramblin Man
England 2012 Range Rover Vogue 4.4 V8 Buckingham Blue
Corrosion Block Grease may be a good alternative: https://www.killerbrands.co.uk/products/co...e-454g-tub TDV8 4.4 2012
Post #652421 3rd Jan 2023 11:11am
Goldstar
I have managed to source a pair from ebay. I'll see how they are when they arrive but as a minimum I will have a new plastic aero part which is the bit that is broken on my current arm
I think a good clean up with a dremel with wire brush and maybe a smear of petroleum jelly will be my approach. Dec 2021- 2010 Facelift TDV8 4.4 AB in Stornoway Grey.
Post #652423 3rd Jan 2023 11:40am
oggy
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
yes you are right haylands do not use copper slip I will amend Thumbs Up new vehicle purchase
2007 supercharged 4.2 java black .sand leather vogue se trim
previous cars .
range rover classic 200 tdi
discovery 1 200 tdi
freelander 2 2008 hse
discovery 1 300 tdi
p38 4.0 ltr man r380 ex royal support vehicle on v5c
discovery td5 man off roader
Post #652460 3rd Jan 2023 6:08pm
