![]() | Home > Technical (L322) > Trans fail prog |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8392 ![]() ![]() ![]() |
Most usual is defective transmission cooler, which mans the engine rad has slush in the bottom as well, the whole lot, including transmission cooler thermostat have to be replaced... You can check this with an IID tool or similar that will show you gearbox oil temp... There are other issues but that's the most common I know of... Pete
Jimes256 Member Since: 14 Mar 2021 Location: Bath Posts: 45 ![]() ![]() ![]() |
Thanks for the reply. I’ve not driven much but had noted it “smelt” hot when getting out and standing next to car. Just assumed it was the v8🤣 what should temps be if my solus can measure? |
Can't remember exactly, shouldn't be much more than 80c and well below 100 IIRC Pete
Thanks. I’m being told elsewhere I should get another reader as the snap on is rubbish for the rr 🤷♂️ So in your experience I should look towards cooler rather than the actual solenoid? |
What solenoid..? Pete
P0571 shift solenoid a is the code I get |
Oh right, you didn't say...
Any gearbox problems can be sorted by RRPhil, our resident gearbox guru...
Will he make an appearance?!🤣 are there contact details for him? |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3199 ![]() ![]() |
he's actually retired but he does pop his head in occasionally. his knowledge is priceless! |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
Quick google has shown up this
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 982 ![]() ![]() |
That code tells us that your shift solenoid MV1 is open circuit i.e. it’s disconnected. This could be a solenoid problem or (more likely) it could be an issue with the transmission wiring harness. To enable us to determine which, it would be helpful if you could disconnect the 16-pin connector at the back of the transmission and measure the resistance between pins 8 & 16. You should measure around 28Ω. If you measure 0Ω then the next step is to remove the sump pan so that you can disconnect the wiring at the solenoid and measure the resistance between the solenoid terminals. Either way, it’s a relatively simple job to sort out. I have spare wiring harnesses and solenoids if you need anything.
Excellent, many thanks Phiil. In normal circumstances I’d be out there now with the multimeter and testing it. Sadly last Sunday I had a bike accident and have fractured shoulder, fractured spine and 6 broken ribs so I’ll waiting to get a mate to put up on ramp on probably Wednesday. Glad it doesn’t sound like a box change. It’s so much nicer than my p38 dse 🙈 |
