Home > Technical (L322) > Trans fail prog |
Jimes256 Member Since: 14 Mar 2021 Location: Bath Posts: 34 |
P0712 |
20th Mar 2021 6:55pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 968 |
The transmission fluid temperature sensor is also part of the transmission wiring harness. Measuring between pins 13 & 14 should give a resistance according to the graph.
21st Mar 2021 1:10am |
Thanks Phil. So this could have got damaged etc when doing valve I suppose. The same error flashed up quickly first time I moved it after doing it(I didn’t do the work as still incapacitated) the fault wasn’t there before so I don’t think the box actuall overheated. Guess the thermistor could be faulty also. Do you think it’s more likely to be loom in pan or wires outside of box? Do the the plugs ever play up? Guess I’m trying to avoid him having to drop the pan again |
21st Mar 2021 7:20am |
Certainly worth trying disconnecting the 16-pin plug & re-connecting in case there’s a poor connection at the pins. Seems a heck of a coincidence that the sensor would fail just at the same time you replaced a solenoid.
21st Mar 2021 12:30pm |
Hi Phil. Any chance of posting pics again? I cant see them |
21st Mar 2021 6:09pm |
Sorry. Not sure what happened there.
21st Mar 2021 6:40pm |
Thank you!! |
21st Mar 2021 8:50pm |
