Home > Technical (L322) > Trans fail prog
Jimes256
United Kingdom 2002 Range Rover Vogue 4.4 V8 Zermatt Silver
Trans fail prog
Hi all. My first l322 and absolutely love it. I have trans fail prog appear after driving a while. The codes are as follows. Any ideas please?
Post #587430 14th Mar 2021 1:51pm
Most usual is defective transmission cooler, which mans the engine rad has slush in the bottom as well, the whole lot, including transmission cooler thermostat have to be replaced... You can check this with an IID tool or similar that will show you gearbox oil temp... There are other issues but that's the most common I know of... Pete
Post #587442 14th Mar 2021 3:47pm
Jimes256
Thanks for the reply. I’ve not driven much but had noted it “smelt” hot when getting out and standing next to car. Just assumed it was the v8🤣 what should temps be if my solus can measure?
Post #587459 14th Mar 2021 6:13pm
Can't remember exactly, shouldn't be much more than 80c and well below 100 IIRC Pete
Post #587483 14th Mar 2021 10:44pm
Jimes256
Thanks. I’m being told elsewhere I should get another reader as the snap on is rubbish for the rr 🤷‍♂️ So in your experience I should look towards cooler rather than the actual solenoid?
Post #587489 14th Mar 2021 11:06pm
What solenoid..? Pete
Post #587491 14th Mar 2021 11:39pm
Jimes256
P0571 shift solenoid a is the code I get
Post #587492 14th Mar 2021 11:40pm
Oh right, you didn't say...
Could be then.... Pete
Post #587494 14th Mar 2021 11:55pm
Jimes256
Post #587499 15th Mar 2021 5:43am
Any gearbox problems can be sorted by RRPhil, our resident gearbox guru...
https://www.fullfatrr.com/forum/member-rrphil.html Pete
Post #587500 15th Mar 2021 6:53am
Jimes256
Will he make an appearance?!🤣 are there contact details for him?
Post #587521 15th Mar 2021 9:12am
Dolphinboy
he's actually retired but he does pop his head in occasionally. his knowledge is priceless! Bow down Bow down Bow down
Post #587547 15th Mar 2021 12:14pm
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
Quick google has shown up this
https://www.troublecodes.net/pcodes/p0751/...80%9D%20is
a good article i thought certainly a good place to start 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #587572 15th Mar 2021 2:54pm
RRPhil
That code tells us that your shift solenoid MV1 is open circuit i.e. it’s disconnected. This could be a solenoid problem or (more likely) it could be an issue with the transmission wiring harness. To enable us to determine which, it would be helpful if you could disconnect the 16-pin connector at the back of the transmission and measure the resistance between pins 8 & 16. You should measure around 28Ω. If you measure 0Ω then the next step is to remove the sump pan so that you can disconnect the wiring at the solenoid and measure the resistance between the solenoid terminals. Either way, it’s a relatively simple job to sort out. I have spare wiring harnesses and solenoids if you need anything.
Phil
Post #587575 15th Mar 2021 3:30pm
Jimes256
Excellent, many thanks Phiil. In normal circumstances I’d be out there now with the multimeter and testing it. Sadly last Sunday I had a bike accident and have fractured shoulder, fractured spine and 6 broken ribs so I’ll waiting to get a mate to put up on ramp on probably Wednesday. Glad it doesn’t sound like a box change. It’s so much nicer than my p38 dse 🙈
Post #587604 15th Mar 2021 8:00pm
