Home > Technical (L322) > Trans fail prog
Jimes256
United Kingdom 2002 Range Rover Vogue 4.4 V8 Zermatt Silver
So update here. Changed valve mv1. After 10mins of first drive I get trans over heat 🤯
Added scan but not sure where it will show 🤷‍♂️🤣
Post #588142 20th Mar 2021 1:42pm
Jimes256
P0712
Post #588189 20th Mar 2021 6:55pm
RRPhil
The transmission fluid temperature sensor is also part of the transmission wiring harness. Measuring between pins 13 & 14 should give a resistance according to the graph.
Phil
Post #588210 21st Mar 2021 1:10am
Jimes256
Thanks Phil. So this could have got damaged etc when doing valve I suppose. The same error flashed up quickly first time I moved it after doing it(I didn’t do the work as still incapacitated) the fault wasn’t there before so I don’t think the box actuall overheated. Guess the thermistor could be faulty also. Do you think it’s more likely to be loom in pan or wires outside of box? Do the the plugs ever play up? Guess I’m trying to avoid him having to drop the pan again
Post #588215 21st Mar 2021 7:20am
RRPhil
Certainly worth trying disconnecting the 16-pin plug & re-connecting in case there’s a poor connection at the pins. Seems a heck of a coincidence that the sensor would fail just at the same time you replaced a solenoid.
[IMG]https://hosting.photobucket.com/albums/ii29/GearShift2008/.highres/16-pin%20connector%20-%20female_zpsftsmfpri.jpg?width=1920&height=1080&fit=bounds[/IMG]
You can also test the pin resistances at the ECU if you want to check the integrity of the transmission wiring all the way through.
[IMG]https://hosting.photobucket.com/albums/ii29/GearShift2008/.highres/Internal%20wiring_zpsdubwimnn.jpg?width=1920&height=1080&fit=bounds[/IMG]
[IMG]https://hosting.photobucket.com/albums/ii29/GearShift2008/.highres/ECU.jpg?width=1920&height=1080&fit=bounds[/IMG]
[IMG]https://hosting.photobucket.com/albums/ii29/GearShift2008/.highres/C1835_zps2d1c6330.jpg?width=1920&height=1080&fit=bounds[/IMG]
[IMG]https://hosting.photobucket.com/albums/ii29/GearShift2008/.highres/TemperatureSensoratECU.jpg?width=1920&height=1080&fit=bounds[/IMG]
[IMG]https://hosting.photobucket.com/albums/ii29/GearShift2008/.highres/C1835.jpg?width=1920&height=1080&fit=bounds[/IMG]
[IMG]https://hosting.photobucket.com/albums/ii29/GearShift2008/.highres/Pin%20table_zpsmq9opqiy.jpg?width=1920&height=1080&fit=bounds[/IMG]
Phil
Post #588250 21st Mar 2021 12:30pm
Jimes256
Hi Phil. Any chance of posting pics again? I cant see them
Post #588296 21st Mar 2021 6:09pm
RRPhil
Sorry. Not sure what happened there.
Phil
Post #588304 21st Mar 2021 6:40pm
Jimes256
Thank you!!
Post #588318 21st Mar 2021 8:50pm
