![]() | Home > Maintenance & Mods (L405) > Land Rover Branded Dashcam Set VPLKV0134 |
pherplexed Member Since: 27 Apr 2010 Location: SC, USA Posts: 69 ![]() ![]() |
I’ve had this working flawlessly for a month or two now. However, the past two days it no longer powers on. Nothing has changed as far as I can tell. Overhead console is functional, no blown fuses.
Inigo Member Since: 15 Jan 2014 Location: Kent Posts: 35 ![]() ![]() ![]() |
I'm having a complete mare with fitting the rear camera. Front camera is in and seems to be working OK. I've managed to get the cable as far as the rear tailgate. I have left my electricians fish tape and pulling lube somewhere else, annoyingly, and am struggling to work out how to get cable through to the tailgate itself. The rubber tube that leads to the tailgate splits further inside the tailgate. Presumably I am supposed to pierce the currently watertight sheath in order to get the cable through.
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1209 ![]() ![]() ![]() |
Getting the wire through the rubber grommet is a pain but doable.
Phil. Member Since: 19 Apr 2010 Location: West Midlands Posts: 791 ![]() ![]() ![]() |
I removed both ends of the rubber grommet and the clip. As above you can then use a piece of wire or flexible plastic cable to pull it through. The grommets push back in place. MY23 D350 HSE
This is how I fixed my rear dashcam - with photos:
