Home > Maintenance & Mods (L405) > Land Rover Branded Dashcam Set VPLKV0134
Page 3 of 4 <1234>
Phil.
Thanks for the update Craig. This seems to be to go to dashcam for RR's going forward, especially if you want the park function. MY23 D350 HSE
On my 7th RR plus various other JLR vehicles
Post #587642 16th Mar 2021 9:01am
Yes you need to fit the wiring through the tailgate sir... Thumbs Up
Post #596627 6th Jun 2021 3:17pm
bestman
Had this fitted yesterday and the install looks neat enough.
It seems to record continuously but in one minute 'chunks' on the SD card - is this right?
Makes reviewing footage a pain.
Post #598039 19th Jun 2021 3:34pm
if like other dashcams you can change the recording time..normally 1,3,5 minute durations. ... - .- -.
Post #598043 19th Jun 2021 4:21pm
Phil.
Generally, the shorter the ‘chunk’ recorded the more reliable the recording. MY23 D350 HSE
Post #598048 19th Jun 2021 5:11pm
why? ... - .- -.
Post #598053 19th Jun 2021 5:49pm
Phil.
It’s to do with the longer the recording session the more risk of any corruption affecting the whole recording. Break the recording down in to smaller chunks and save each chunk, then if one chunk becomes corrupt the others are safe. Here’s someone else explaining it:
‘’FAT32 has an inherent limit of file size which limits the possibilities. Most folks find 3-5 minutes easier to work with when viewing or looking for a specific incident. Should a file's data get corrupted (rarely happens with good cards and cams) a smaller file size means less recording lost. I've gone from 5 minutes to 3 minutes as what I like, but one cam I use does 1 minute files and I'm OK with that too. It's really just personal preference.’’
https://dashcamtalk.com/forum/threads/loop...gth.33297/
The main thing is not to scrimp on the memory card and buy the best you can find that’s most suitable for your dashcam. MY23 D350 HSE
Post #598055 19th Jun 2021 6:03pm
bestman
Cheers Gents -
The Land Rover one does not give options - it's one minute clips I guess, but from what's been said, that seems reasonable.
Second question - I can see on the App that the rear camera is recording, when I play back the 'chunk,' I get to select which camera to view. However when I download from the card to my computer, the resulting 1 min MP4s, don't allow me to see the rear camera footage.
This is what would I guess woud be useful after an accident etc So how would I produce a fie of the rear footage?
Post #598058 19th Jun 2021 6:35pm
Phil.
I’ve always been able to retrieve both the front and rear clips off the SD card. The file names usually have different extensions.
Is it possible that the LR dashcam uses more than one SD card, one for the front and one for the rear?
I’m sure Craig will be along to advise soon enough. MY23 D350 HSE
Post #598073 19th Jun 2021 7:48pm
i doubt whether a £500'ish dashcam would have corrupt recordings.. ... - .- -.
Post #598075 19th Jun 2021 8:03pm
bestman
I can see the clips, from both front and rear cams on the App, and download the same footage to the App under what appears to be the same file. But I can’t export from the app, and if I download straight from the SD card, the rear footage isn’t accessible.
So I can’t see how one could ‘produce’ rear camera footage for evidence if required.
I’ve checked and I can’t see that the rear cam has its own SD card.
Anyone got any insights?
Post #598309 21st Jun 2021 9:05pm
Ajay(UK)
United Kingdom 2015 Range Rover Autobiography SDV8 Indus Silver
Craig, any update on how the Land Rover Dash Cam is performing? I am weighing up the Pro's & Con's of fitting a Blackvue vs Land Rover OEM Dash Cam for my wife's new Defender Confused
Cheers,
Andy. 22MY Defender 110 D250 HSE X Dynamic, Gondwana Stone.
SWMBO: 2022 RRS D300 Autobiography, Firenze Red.
Gone:2015 L405 SDV8 Autobiography, Indus Silver with Black Pack.
Gone: 2014 Discovery 4 HSE Luxury Firenze Red
Gone: 2006MY Java Black TD6 Autobiography
Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats
Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE
Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD
Post #600602 14th Jul 2021 10:38am
Chalky
The LR dashcams are very good indeed.. Thumbs Up Thumbs Up The video recordings are very clear and the voice is not irritating like the Blackvue.
My wife has the blackvues and even she gets annoyed with the voice every time she gets in the car!!
The other main advantage of the LR cams is they don't drain the battery in parking mode unlike the Blackvues which have a known problem. I had to switch them off in my last FFRR. All LR cars from 1984
2021.5 Vogue SE D300 Carpathian Grey
2018 Vogue SE British Racing Green GONE
Post #600605 14th Jul 2021 10:52am
pherplexed
United States
Cam-Tech-Craig wrote:
Phil, I took the same route as you through the rubber sleeve at the hinge point of the tailgate, however, I then removed the boot spoiler and fed the wire with the main loom across to the RHS of the tailgate. I then fed the wire down through the right side channel (again where the main loom runs) this is where my install slightly differs from yours Phil, the main loom exits into the void behind the boot light panel (the one you removed) I then drilled the panel installed a grommet for the wire to exit next to the camera position... IMHO it makes a slightly better install following the main loom across and down the RHS following the channel the loom takes. Then the wire is weather proof and you negate the need to drill the tailgate! 👍
Craig - I’m working on this same install and I’m struggling to get through this tailgate part. How do you get the wire through the rubber sleeve without damaging anything? 2021 P525 | Eiger Gray
Post #657180 20th Feb 2023 3:22am
zenman63
England 2016 Range Rover Autobiography SDV8 Indus Silver
Wd40 spray inside the rubber boot and the wires sale through
Post #657633 24th Feb 2023 1:06pm
Page 3 of 4 <1234>
