![]() | Home > Technical (L322) > TD6 starting |
dantheman Member Since: 02 Feb 2009 Location: North: Lancs Posts: 477 ![]() ![]() |
Hi mate - not had any experience with the fuel system on this vehicle (except paying through the nose to keep it drinking!)... are you sure you're barking up the right tree thinking of fuel pumps? If they were going pete tong generally, you may:
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35526 ![]() ![]() |
same as dan, my td6 starts every time ..the only problem members have had is a flat battery but then the thing will struggle to turn over and maybe not at at all...how old is the battery btw, 3 years 'ish is about tops generally.. ... - .- -.
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
The secondary fuel pump is a common failure point on these vehicles |
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 ![]() ![]() ![]() |
Thank for replies guys... |
Have a look here - not a bad explanation of pump cavitation:
Right, took it round the block a few times then back to drive to try start it. Then it done it, decided not to start.
good news ,at least you now know what it is |
Probably an idea to check connections... potentially an easy fix there. I'd be gutted if I'd changed a pump complete when there was just a loose connection/damaged cable that could be repaired. |
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 ![]() ![]() ![]() |
How much fuel is in? Pump works harder on a lower tank. If its low then this may support a worn pump theory. 2010 Disco XS TDV6, 2009 Freelander 2 GS
It failed to start again so had another look, and im glad i did as its the secondary pump not cutting in, not the main pump. Its under a hatch attached to the tank and this time i just rocked this pump alone and it started spinning. Connections look fine so new one on order.
Sorry couple more questions
Anything before the FIP is generally low pressure so you should be just fine in the case of a fuel lift pump. |
thanks mate... |
No worries mate - hope all goes well. |
