![]() | Home > Technical (L322) > TD6 starting |
liverpoolphil Member Since: 28 Jan 2010 Location: Lancashire Posts: 111 ![]() ![]() ![]() |
top post - great information ![]() |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3765 ![]() ![]() |
sticky or Wiki? should be |
mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425 ![]() ![]() ![]() |
Mines started to do exactly the same |
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 ![]() ![]() ![]() |
Access to the primary pump that is in the tank is from under the rear seat. The secondary pump which i had to replace is accessed from under the car, get under just in front of the nearside rear wheel and look for a hatch with two bolts, the secondary pump is behind that. When ignition on 11 you should be able to here both pumps prime, slight hum from tank offside is your primary and as above for secondary. The secondary pump is standard across alot of cars so don't get ripped of at land rover for £130, I bought mine here; http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...K:MEWNX:IT offered the guy £50 he came back with £55. If you need a brand buy the BMW one, should be cheaper than land rover, part numbers on same link above. Good Luck, keep us informed.... ![]() |
Cheers - I had a look at that one last night |
hows it going mercs, you get your pump? sorted the problem? 2004 black Vogue TD6 |
Right - recieved the pump today and fitted it in approx 15-30 mins - no problem.
Forgot to add - when it starts it runs fine - no smoke etc and no hesitation/loss of power or missing - runs very smoothly !
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35528 ![]() ![]() |
this is a bit long but very interesting...
Is it a hot start only issue? coolant sensor? you plugged in a OBD, any codes?
There is no white smoke on start up and no black smoke when running or under acceleration.It does it when the engine is cold and when the engine is warm - but I would say it is more difficult to start when warm (requires and extra 10-20 seconds of cranking over). The battery is good and spins the emgine over fast enough with no drop in crancking speed.
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 ![]() ![]() ![]() |
Have a browse through this....
Right - had a damn good look around the engine (top and bottom) to see if any pipes were off etc - all OK.
Many thanks to all that made suggestions - it's now fixed and starting as it should |
