Home > Technical (L322) > TD6 starting
Page 1 of 3 123>
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
TD6 starting
Twice now my TD6 has failed to start, both time's it started after being left for a while.
Turning over ok so battery seems fine, just dont fire up. I'm leaning towards fuel pumps but what one? how to test? can hear one\both prime when down by the tank and i turn the ignition on.
Dont want the missis and kids stranded.
Any other ideas or advice before i trade this POS in. 2004 black Vogue TD6
Post #62171 29th Apr 2011 10:55pm
dantheman
Hi mate - not had any experience with the fuel system on this vehicle (except paying through the nose to keep it drinking!)... are you sure you're barking up the right tree thinking of fuel pumps? If they were going pete tong generally, you may:
-hear cavitation from the pump (or racing? depending on pump type)
-suffer power loss (engine may strart/idle fine but lose power when more fuel is required under load)
What is the flow rate of the pump? I presume this is quoted somewhere so you can check.
Also, are you suffering from an interrupted electrical feed to the pump? Is there an error/fault code?
Sorry I can't be much more help, but as above I have had very little go wrong with mine.
Post #62175 29th Apr 2011 11:18pm
same as dan, my td6 starts every time ..the only problem members have had is a flat battery but then the thing will struggle to turn over and maybe not at at all...how old is the battery btw, 3 years 'ish is about tops generally.. ... - .- -.
Post #62186 30th Apr 2011 8:11am
The secondary fuel pump is a common failure point on these vehicles
Post #62188 30th Apr 2011 8:25am
letsavit2
Thank for replies guys... Thumbs Up
dan, can you explain "cavitation", i can hear the pump\s prime. mabe sounds a little noisy but no knocking etc. Might be barking up wrong tree but i have no other clues, no fault codes\messages, driving fine when started. i cant even get it to reacure, but it's done it twice in a week so i know it will do it again.
scarey, yes new battery 8 months ago, she seems to be turning over strongly. Even watched tele yesterday while waiting for the range rover to decide to start.... Laughing
47p2, yes, the secondary pump has come up a few times when searching for info, might be worth shot gunning this part. 2004 black Vogue TD6
Post #62196 30th Apr 2011 9:46am
dantheman
Have a look here - not a bad explanation of pump cavitation:
http://www.engineersedge.com/pumps/cavitation.htm
Post #62199 30th Apr 2011 10:15am
letsavit2
Right, took it round the block a few times then back to drive to try start it. Then it done it, decided not to start.
Got under and listened for pump, very faint hum i assume from the secondary pump. i then bashed the tank a few times and heard the noiser pump cut in. She then started.
So looks like the main pump in the tank, loose conection or on way out, but at 80k ill think i just replace Looked on Rave and does not mention taking rear seat out but i know i have read that somewhere. Anymore information by someone who has done this job would be appreciated. 2004 black Vogue TD6
Post #62207 30th Apr 2011 11:07am
good news ,at least you now know what it is Thumbs Up ... - .- -.
Post #62208 30th Apr 2011 11:12am
dantheman
Probably an idea to check connections... potentially an easy fix there. I'd be gutted if I'd changed a pump complete when there was just a loose connection/damaged cable that could be repaired.
Post #62210 30th Apr 2011 11:23am
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
How much fuel is in? Pump works harder on a lower tank. If its low then this may support a worn pump theory. 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #62217 30th Apr 2011 2:08pm
letsavit2
It failed to start again so had another look, and im glad i did as its the secondary pump not cutting in, not the main pump. Its under a hatch attached to the tank and this time i just rocked this pump alone and it started spinning. Connections look fine so new one on order.
Thanks for the help guys... Thumbs Up
Ill reply when done (hopefully) with symptoms etc for others searching. 2004 black Vogue TD6
Post #62241 30th Apr 2011 8:28pm
letsavit2
Sorry couple more questions
Am i correct in assuming i can just remove this pump with ignition off? i know its a high pressure system. Ill prob clamp the hoses each side just to be safe. This pump also looks to have ear hose clips, nothing special but ill have to break them off, once again with regards to being a high pressue system reckon normal jubilee clips will suffice?
thinking about the above, the fuel filter's on the same system so cant be any different to changing that.
Rave is very vague on this for the TD6, the whole system is based on the petrol v8... Confused 2004 black Vogue TD6
Post #62256 30th Apr 2011 10:17pm
dantheman
Anything before the FIP is generally low pressure so you should be just fine in the case of a fuel lift pump.
Post #62258 30th Apr 2011 10:31pm
letsavit2
thanks mate... Wink 2004 black Vogue TD6
Post #62262 30th Apr 2011 11:18pm
dantheman
No worries mate - hope all goes well. Thumbs Up
Post #62273 1st May 2011 9:24am
Page 1 of 3 123>
