Home > Maintenance & Mods (L405) > Just in time for winter...remote climate retrofit |
capcgn Member Since: 21 Sep 2011 Location: Cologne Posts: 29 |
I did search all the way up to the SRS module in the rigth rear pillar, no luck |
27th Jan 2021 9:26am |
I have located the loom up to the SRS unit and it is not there. Im 100% sure |
27th Jan 2021 9:38am |
Phil. Member Since: 19 Apr 2010 Location: West Midlands Posts: 786 |
If you do find the connectors please let us know as I am still keen to fit the remote unit too. MY23 D350 HSE
27th Jan 2021 10:11am |
Yes I will, maybe a pro can give me a instruction to remouve the D-pillar cover inside, so I can see if the loom is more up at the D- pillar. Thanks for help..... |
27th Jan 2021 10:15am |
I managed to remouve the inside D-pillar cover on the rigth side of my car. The loom is 100% not prepared to have the remout control unit there. No cables or antenna present. The location for the remoute control unit is occupied by the SRC unit. I think and hope, the location was changed to another place. Maybe one of you can check in the workshop manual for the location of the unit for 2016 and up models. Thank you. |
28th Jan 2021 11:22am |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 768 |
The location is still the same on 2016 according to my manual. However, I think we have to conclude that your investigation has proven the wiring is not present. What are you referring to as the SRC unit? Supplementary Restraint Control?
28th Jan 2021 10:07pm |
Thank you for the fast replay. The box behind the D-pillar in my car is to my undestanding from the airbag SRS ( Sorry not SRC ) It is wrapped in foam. No other cables or antenna connector are present. |
29th Jan 2021 8:17am |
Fifth Horseman Member Since: 04 Jul 2016 Location: Lanarkshire Posts: 229 |
Before you go searching for the connectors in the D-pillar it is worth checking that the required wiring is present at the FBH power connector. If the vehicle is wired for radio-remote FBH operation there will be a thin brown/violet wire at pin 4 on the left hand side of connector C1HF01A shown in the picture below:
29th Jan 2021 4:28pm |
Thank you for your help. I checked and yes I do have the thinn brown cable with a blue stripe. |
30th Jan 2021 8:56am |
aljo Member Since: 04 Jul 2018 Location: west sussex Posts: 202 |
Following with interest as I have had no luck finding the connectors
30th Jan 2021 9:06am |
On this wiring diagram the wire from receiver is brown/ violet
30th Jan 2021 10:00am |
Mines the Webasto unit (MY19). Where should I be looking for the brown/violet wire?
30th Jan 2021 1:21pm |
Looking at the photo, I would say you need to look on the right hand side of the large grey connector next to the FBH. A word of caution, the later vehicles with the Webasto may have a different colour code, I've not seen any wiring diagrams for these - also my note earlier was wrong for the colour of the wire (must wear glasses more often ) the wire you are looking for is Brown/Violet - the Brown/Blue one is for the heater fuel pump. |
31st Jan 2021 8:34am |
154JON Member Since: 31 Mar 2019 Location: Essex Posts: 129 |
Evening all just after any possible thoughts and help, today fitted a new receiver and updated CCF with IID tool and timer climate option came up on screen, tried several times but could not get the remote to pair, removed fuse 1 and put back after 10 seconds, held down off button but light went green then flashed red quite quickly which seems to mean no communication with the receiver, does the ignition need to be on or off when the fuse is removed and replaced. I have set the timed climate to come on in the morning for a single use to see if it will work that ways that likely to happen without the remote being paired and does the diesel heater make quite a noise and make it quite obvious when its running.
8th Feb 2021 9:01pm |
