Home > Technical (L405) > 6 pot callipers
Page 2 of 3 <123>
GraemeS
The 4-pots were labelled Brembo whereas the 6-pot, at least on the L322, do not have Brembo on them, making the 1st picture 4-pots and the 2nd 6-pots.
Post #533214 5th Nov 2019 10:33am
Mikey
Cam-Tech-Craig wrote:
Mikey wrote:
Same brakes as the early L320's Thumbs Up
So... 4 pot not 6!
Bit of a generalising statement that, I'll explain more...
Caliper carriers on the early Sport + D3 are the same.
4 pot Brembos fit both cars
Hub carriers on the facelift Sport are the same as the early Sport/D3 (Not strictly true, but for this purpose, they are)
Facelift Sport has 6 pots
Therefore, 6 pots fit Disco 3
All 6 pot calipers are interchangeable between L320/L405/L494 and can also be fitted to the L319 Thumbs Up
Post #533224 5th Nov 2019 12:49pm
Greyskull
England 2009 Range Rover Vogue SE TDV8 Buckingham Blue
Hi all I’m in the middle of up grading my calipers to 6pot calipers off a L322 TDV8.. and they do say brembo on them
Post #533250 5th Nov 2019 7:19pm
GraemeS
MY07-09 L322 3.6 TDV8 have 4-pot Brembos.
Post #533252 5th Nov 2019 7:43pm
GraemeS
Aren't the mounting bolt holes in the 6-pots larger than the 4-pots?
Post #533253 5th Nov 2019 7:47pm
Greyskull
pre 09 have different hubs to 09 to 12 l322 i used info from an exellent post in wiki with part nos 👍👍
Post #533257 5th Nov 2019 8:03pm
Mikey
Only on the L322 Thumbs Up
Post #533261 5th Nov 2019 9:13pm
So... 4 pot not 6!
Yawn So, you've either changed the hub assemblies on your D3 or drilled the carrier holes to receive the 6 pots right??? Rolling Eyes
Post #533275 6th Nov 2019 12:21am
Mikey
No Rolling Eyes
Standard D3 hub carriers. Which are the same as RRS*, which came with standard brakes, 4 pots and 6 pots. Bolt on upgrade
The D3 only came with the same standard brakes, 4/6 pots were never an option
The only modification needed is a new backplate (plus discs, pads, calipers, wear sensor, to avoid any confusion Rolling Eyes) which also bolts on
*same, but different
Post #533277 6th Nov 2019 6:16am
And that makes absolutely NO sense Mickey! How can you bolt both a 4 pot & a 6 pot calliper on the same cast hub? The bolt diameters are quite different!
Hence only 09MY> FF’s having the correct hub castings to fit 6 pots!
And pre 09MY only the 4 POT!
Post #533295 6th Nov 2019 9:15am
Mikey
No, they are not. They are the same
The only difference is on the L322, where the hubs/calipers were changed at 2010MY
D3/RRS hub have always had the bigger hubs, allowing fitment of both 4 pot Brembo's from a Range Rover Sport, as well as 6 pot Brembo's from a Range Rover Sport, which are compatible with ALL 6 pot calipers from ALL RRS/L322/L405 models
Post #533308 6th Nov 2019 12:28pm
WOW! OK....
Im not going to sit here and argue with your logic! or lack of it! re read your posts above, they contradict each other!...
Suffice to say my 2004MY D3 could only take 4 pot callipers from the RRS SC with the smaller mounting bolts! Our present 15MY D4 has 6 pot callipers with the MUCH larger mounting bolts! The D3 HSE (we owned) had a different hub & brake mounting size
My 2003MY TD6 L322 had 4 pot Brembo's from an SC! My later 2006MY L322 SC obviously had 4 pots from factory! And my 2011 last of the line 4.4 TDV8 came with 6 pots. These we took off and had the colour changed!
All of the callipers i have removed at some time or another to paint etc
Post #533375 7th Nov 2019 1:25am
Mikey
No Craig, the caliper mounting holes are the same size between D3, D4, RRS and later L322 hubs.
The 4 pots from a Sport fit because they are the same size mounts as the D3, which is the same as the D4
The only Brembo calipers with the smaller mounting holes are from the 02-09 L322
No Disco 3 ever left the factory with calipers requiring the smaller mounts
Jeez Rolling Eyes
Post #533376 7th Nov 2019 1:45am
GraemeS
Microcat 2012 agrees with you Mikey - thanks. I didn't contemplate the possibility that the 4-pots fitted to L322s might not be the same as those fitted to L320s although possibly just the holes drilled larger for non-L322 fitment.
Post #533392 7th Nov 2019 9:23am
Mikey
Thumbs Up Thumbs Up
Post #533514 8th Nov 2019 12:52pm
Page 2 of 3 <123>
