Home > Technical (L405) > 6 pot callipers
Page 1 of 3 123>
Felstmiester
England 2015 Range Rover Vogue TDV6 Santorini Black
6 pot callipers
Im assuming the brembo 6 pots only come on the supercharged L405? And also am I right to assume the ones off the sport would bolt straight on the L405?
I’m going to need new front discs soon and was thinking of getting hold of some second hand 6 pots and bigger discs. Just need to know what to look out for.
Post #532705 30th Oct 2019 9:38pm
Red Merle
United Kingdom 2017 Range Rover Autobiography SDV8 Aintree Green
They’re on the SDV8.
Post #532707 30th Oct 2019 9:45pm
Felstmiester
All of the sdv8 L405’s ?
Post #532708 30th Oct 2019 9:56pm
Red Merle
I can’t speak for anything prior to MY17, but certainly from then onwards Thumbs Up
Post #532711 31st Oct 2019 3:08am
Mikey
All 6 pots from L320/L322/L405/L494 are all interchangeable Thumbs Up
Post #532712 31st Oct 2019 5:23am
Felstmiester
The earlier model brembo’s was different though wasn’t they? If they’re not I’m gutted because I done the conversion on our disco to brembo but didn’t swap it back when I sold it because I thought they was smaller than the ones they put on the L405.
Post #532714 31st Oct 2019 7:39am
All JLR Brembo 6 pot callipers are the same LH & RH fitment... The earlier 4 pot callipers will NOT fit on a newer (2009>) models...
So, if you had a D4 and you fitted 6 pot callipers then yes 100% they would have fitted! (But the D4 uses Sport discs)
If you had a D3 with 4 pot callipers then NO they would not fit sir...
And just for clarity's sake... All L405's 2012-2018 EXEPT the 3.0 TDV6 came with 6 pot Brembo callipers! Petrol & Diesel! im unsure from 2018> But i suspect the same applies...
You would theoretically need Callipers, discs, backing plates, pads & wires Thumbs Up
Post #532738 31st Oct 2019 11:06am
Felstmiester
No offence to anyone but I knew you was the man to answer this question. In a way I’ve had a result then as I’ve found a breaker that has a sdv8
Post #532746 31st Oct 2019 11:46am
jz
Seeing Mickley's comment so just to confirm, are all 6pots 100% inter-changeable across L322s, L320s, L405s
etc as thought that wasnt the case?
Post #533105 4th Nov 2019 10:12am
Mikey
Ahem... Whistle
Post #533166 4th Nov 2019 6:50pm
And the 6 pots just bolt on to the existing hubs of a D3 do they Mickey???
Post #533183 4th Nov 2019 8:53pm
Mikey
Same brakes as the early L320's Thumbs Up
Post #533204 5th Nov 2019 8:31am
GraemeS
My brother's MY08 3.6 TDV8 RRS has 4-pot Brembos not 6.
Post #533207 5th Nov 2019 9:19am
So... 4 pot not 6!
Post #533212 5th Nov 2019 10:07am
jz
Gents, sorry but just to be clear - as selling my 2010 L320 which has 6 pots, are they a straight fit for my 2011 L322 SC as would mind swapping them over as they're better condition but dont want to waste my time local mechanic if not?
Post #533213 5th Nov 2019 10:27am
Page 1 of 3 123>
