Home > Technical (L405) > 6 pot callipers |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1784 |
Bit of a generalising statement that, I'll explain more... Caliper carriers on the early Sport + D3 are the same. 4 pot Brembos fit both cars Hub carriers on the facelift Sport are the same as the early Sport/D3 (Not strictly true, but for this purpose, they are) Facelift Sport has 6 pots Therefore, 6 pots fit Disco 3 All 6 pot calipers are interchangeable between L320/L405/L494 and can also be fitted to the L319 |
5th Nov 2019 12:49pm |
Greyskull Member Since: 13 Jun 2019 Location: Selby North Yorkshire Posts: 49 |
Hi all I’m in the middle of up grading my calipers to 6pot calipers off a L322 TDV8.. and they do say brembo on them |
5th Nov 2019 7:19pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2556 |
MY07-09 L322 3.6 TDV8 have 4-pot Brembos. |
5th Nov 2019 7:43pm |
Aren't the mounting bolt holes in the 6-pots larger than the 4-pots? |
5th Nov 2019 7:47pm |
pre 09 have different hubs to 09 to 12 l322 i used info from an exellent post in wiki with part nos 👍👍 |
5th Nov 2019 8:03pm |
Only on the L322 |
5th Nov 2019 9:13pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 |
So, you've either changed the hub assemblies on your D3 or drilled the carrier holes to receive the 6 pots right??? |
6th Nov 2019 12:21am |
No
6th Nov 2019 6:16am |
And that makes absolutely NO sense Mickey! How can you bolt both a 4 pot & a 6 pot calliper on the same cast hub? The bolt diameters are quite different!
6th Nov 2019 9:15am |
No, they are not. They are the same The only difference is on the L322, where the hubs/calipers were changed at 2010MY D3/RRS hub have always had the bigger hubs, allowing fitment of both 4 pot Brembo's from a Range Rover Sport, as well as 6 pot Brembo's from a Range Rover Sport, which are compatible with ALL 6 pot calipers from ALL RRS/L322/L405 models |
6th Nov 2019 12:28pm |
WOW! OK....
7th Nov 2019 1:25am |
No Craig, the caliper mounting holes are the same size between D3, D4, RRS and later L322 hubs.
7th Nov 2019 1:45am |
Microcat 2012 agrees with you Mikey - thanks. I didn't contemplate the possibility that the 4-pots fitted to L322s might not be the same as those fitted to L320s although possibly just the holes drilled larger for non-L322 fitment. |
7th Nov 2019 9:23am |
8th Nov 2019 12:52pm |
