![]() | Home > Technical (L405) > 6 pot callipers |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1789 ![]() ![]() |
Bit of a generalising statement that, I'll explain more... Caliper carriers on the early Sport + D3 are the same. 4 pot Brembos fit both cars Hub carriers on the facelift Sport are the same as the early Sport/D3 (Not strictly true, but for this purpose, they are) Facelift Sport has 6 pots Therefore, 6 pots fit Disco 3 All 6 pot calipers are interchangeable between L320/L405/L494 and can also be fitted to the L319 ![]() |
Greyskull Member Since: 13 Jun 2019 Location: Selby North Yorkshire Posts: 49 ![]() ![]() ![]() |
Hi all I’m in the middle of up grading my calipers to 6pot calipers off a L322 TDV8.. and they do say brembo on them |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2575 ![]() ![]() ![]() |
MY07-09 L322 3.6 TDV8 have 4-pot Brembos. |
Aren't the mounting bolt holes in the 6-pots larger than the 4-pots? |
pre 09 have different hubs to 09 to 12 l322 i used info from an exellent post in wiki with part nos 👍👍 |
Only on the L322 ![]() |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
No |
And that makes absolutely NO sense Mickey! How can you bolt both a 4 pot & a 6 pot calliper on the same cast hub? The bolt diameters are quite different!
No, they are not. They are the same The only difference is on the L322, where the hubs/calipers were changed at 2010MY D3/RRS hub have always had the bigger hubs, allowing fitment of both 4 pot Brembo's from a Range Rover Sport, as well as 6 pot Brembo's from a Range Rover Sport, which are compatible with ALL 6 pot calipers from ALL RRS/L322/L405 models |
WOW! OK....
No Craig, the caliper mounting holes are the same size between D3, D4, RRS and later L322 hubs.
Microcat 2012 agrees with you Mikey - thanks. I didn't contemplate the possibility that the 4-pots fitted to L322s might not be the same as those fitted to L320s although possibly just the holes drilled larger for non-L322 fitment. |
