Home > Technical (L405) > Jacking the L405 with side steps
Page 1 of 3 123>
jackcramerr
L405 2015 5.0L
How can the factory jack be used to raise the car for tyre change if deploy-able side steps are in the way?
Manual says that the side steps should be in stored position before jacking up.
For a 2016, the owner's manual says it should be in deployed position.
Now if the side steps are in stored position, the factory jack points cannot be accessed. I noticed even in deployed position, it still cannot be accessed.
Did Range Rover got it wrong or is there a trick to it?
I have attached pictures of service manual and owners manual for 2015.
In 2015 it simply says that jack points will be obscured if the side steps are in stored position. Then goes on to say to use jacking point of front and rear side of the steps... what does that mean?
Thanks.
Post #530736 13th Oct 2019 12:56pm
Your missing a trick sir... Whistle
The steps become your jacking point, hence they should be in the stow'd position before jacking underneath the hinges Thumbs Up
Post #530738 13th Oct 2019 12:58pm
jackcramerr
Thanks for the fast reply cam-tech-craig.
Where is this location?
I am going to try and take a picture if you can please mark it? Unless you have a picture of it?
Post #530740 13th Oct 2019 1:02pm
you missed another trick, dont use the factory jack! get yourself a merc sprinter bottle jack..[other suitable bottle jacks can be used] ... - .- -.
Post #530741 13th Oct 2019 1:09pm
Look in your owners manual and you will see the jacking point is exactly the same shape as the underside of the step hinge... That way you will know where to jack it sir... Thumbs Up
Post #530743 13th Oct 2019 1:15pm
This im sure will help you sir...
https://www.fullfatrr.com/forum/post475269.html
Post #530744 13th Oct 2019 1:18pm
jackcramerr
Does this picture help?
Can you please mark it ? Much appreciated. Thanks.
Post #530745 13th Oct 2019 1:31pm
jackcramerr
Actually, I couldn't find it in the owners manual.
Post #530746 13th Oct 2019 1:35pm
jackcramerr
I have a 2.5 ton trolley jack. But if I jack up using that, where will I place the jack stands then?
Post #530771 13th Oct 2019 4:48pm
It's the very lowest point that you jack from - dead easy with a trolley jack Thumbs Up
https://www.fullfatrr.com/forum/topic47066.html
There's a separate supplement for the deployable steps
Post #530772 13th Oct 2019 4:59pm
jackcramerr
The lowest point is the one I marked in yellow. Is that it then? But that is plastic part of deployable side step..
Post #530773 13th Oct 2019 5:24pm
jackcramerr
Also, am I correct to say this is the point for jack stand or trolley jack as stated in the Workshop manual?
Post #530775 13th Oct 2019 5:27pm
Yes the yellow part and NO its not plastic! Its metal...
Post #530776 13th Oct 2019 5:28pm
jackcramerr
I'll see if a magnet sticks to it as when I touched it, knocked it, it didn't feel like metal.
I am also posting picture of the jack just in case anyone needs it for future. As this post might help someone in future.
Post #530786 13th Oct 2019 6:57pm
jackcramerr
[quote="Alistair"]It's the very lowest point that you jack from - dead easy with a trolley jack Thumbs Up
How will trolley jack be able to work/hold the curved surface? Notice the factory jack has a slot/grove.
Post #530788 13th Oct 2019 7:04pm
Page 1 of 3 123>
