Home > Technical (L405) > Jacking the L405 with side steps |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 |
Your missing a trick sir...
13th Oct 2019 12:58pm |
jackcramerr Member Since: 13 Oct 2019 Location: London Posts: 220 |
Thanks for the fast reply cam-tech-craig.
13th Oct 2019 1:02pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35476 |
you missed another trick, dont use the factory jack! get yourself a merc sprinter bottle jack..[other suitable bottle jacks can be used] ... - .- -.
13th Oct 2019 1:09pm |
Look in your owners manual and you will see the jacking point is exactly the same shape as the underside of the step hinge... That way you will know where to jack it sir... |
13th Oct 2019 1:15pm |
This im sure will help you sir...
13th Oct 2019 1:18pm |
Does this picture help?
13th Oct 2019 1:31pm |
Actually, I couldn't find it in the owners manual. |
13th Oct 2019 1:35pm |
I have a 2.5 ton trolley jack. But if I jack up using that, where will I place the jack stands then?
13th Oct 2019 4:48pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7969 |
It's the very lowest point that you jack from - dead easy with a trolley jack
There's a separate supplement for the deployable steps |
13th Oct 2019 4:59pm |
The lowest point is the one I marked in yellow. Is that it then? But that is plastic part of deployable side step..
13th Oct 2019 5:24pm |
Also, am I correct to say this is the point for jack stand or trolley jack as stated in the Workshop manual?
13th Oct 2019 5:27pm |
Yes the yellow part and NO its not plastic! Its metal... |
13th Oct 2019 5:28pm |
I'll see if a magnet sticks to it as when I touched it, knocked it, it didn't feel like metal.
13th Oct 2019 6:57pm |
[quote="Alistair"]It's the very lowest point that you jack from - dead easy with a trolley jack
13th Oct 2019 7:04pm |
