![]() | Home > Technical (L405) > stop start |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35629 ![]() ![]() |
thats weird...the 2013 to 2015 had aux batterys and from then i thought they went with the capacitor setup like mine....
edit, just read the WM and it seems that 4.4 engines have the aux battery.. ... - .- -.
yep.....if it causes any problems,which I'm pretty sure it won't ,you then reconnect... ... - .- -.
Heyloft Member Since: 28 Apr 2012 Location: UK Posts: 64 ![]() ![]() |
I know this thread is about getting stop/start not working but I want mine to work and it won’t.
It will be battery related!
Yep got that it’s battery related
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3783 ![]() ![]() |
If you disable the Stop Start on the 4.4 it will also disable your heated seats 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
hasnt on mine...in fact everything works as it should.. ... - .- -.
It will Stan - yours is the V6 - it’s the SDV8 the heated seats stops working on 👍🏻 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
interesting..i wonder if any other 4.4 owner has this problem.. ... - .- -.
JNC Member Since: 23 Feb 2020 Location: UK Posts: 293 ![]() ![]() ![]() |
Following on from this. Has anyone done a diag/iid tool scan after disconnected the aux battery?
ive never had a dpf warning since the mod and never since ive had mine...
Do you have fault code for battery when you scan vehicle? |
mines a capacitor so no battery fault code. ... - .- -.
