Home > Technical (L405) > stop start |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35436 |
thats weird...the 2013 to 2015 had aux batterys and from then i thought they went with the capacitor setup like mine....
23rd Sep 2019 5:10pm |
edit, just read the WM and it seems that 4.4 engines have the aux battery.. ... - .- -.
23rd Sep 2019 5:16pm |
yep.....if it causes any problems,which I'm pretty sure it won't ,you then reconnect... ... - .- -.
23rd Sep 2019 6:45pm |
Heyloft Member Since: 28 Apr 2012 Location: UK Posts: 64 |
I know this thread is about getting stop/start not working but I want mine to work and it won’t.
27th Feb 2020 6:31pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16302 |
It will be battery related!
27th Feb 2020 7:22pm |
Yep got that it’s battery related
27th Feb 2020 7:33pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3754 |
If you disable the Stop Start on the 4.4 it will also disable your heated seats 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
9th Mar 2020 3:41pm |
hasnt on mine...in fact everything works as it should.. ... - .- -.
9th Mar 2020 3:58pm |
It will Stan - yours is the V6 - it’s the SDV8 the heated seats stops working on 👍🏻 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
9th Mar 2020 6:30pm |
interesting..i wonder if any other 4.4 owner has this problem.. ... - .- -.
9th Mar 2020 6:39pm |
JNC Member Since: 23 Feb 2020 Location: UK Posts: 292 |
Following on from this. Has anyone done a diag/iid tool scan after disconnected the aux battery?
15th Jan 2021 6:34pm |
ive never had a dpf warning since the mod and never since ive had mine...
15th Jan 2021 7:17pm |
Do you have fault code for battery when you scan vehicle? |
17th Jan 2021 12:14am |
mines a capacitor so no battery fault code. ... - .- -.
17th Jan 2021 8:25am |
