Home > Technical (L405) > stop start
Page 4 of 5 <12345>
thats weird...the 2013 to 2015 had aux batterys and from then i thought they went with the capacitor setup like mine....
if you have a main battery in the floor well by the compressor then you then have an aux battery [as in your pic]
you can just disconnect the earth terminal and isolate it , ie wrap it in tape... ... - .- -.
Post #528868 23rd Sep 2019 5:10pm
edit, just read the WM and it seems that 4.4 engines have the aux battery.. ... - .- -.
Post #528870 23rd Sep 2019 5:16pm
Ukandrewf
so disconnect here and wrap? as you may have gathered i don't have a clue Smile but this start/stop is really annoying me.
On my third Full Fat RR
Post #528874 23rd Sep 2019 6:09pm
yep.....if it causes any problems,which I'm pretty sure it won't ,you then reconnect... ... - .- -.
Post #528880 23rd Sep 2019 6:45pm
Heyloft
2019 Range Rover Vogue SE SDV8 Carpathian Grey
I know this thread is about getting stop/start not working but I want mine to work and it won’t.
I know you guys don’t like it, but I’ve only just bought the 13 month old car and I want everything to work.
The dealer said it was the main battery and they’d charged it. I didn’t buy their explanation so I checked the Aux battery when I got home and it says 0% charge and 7.2v so it’s either
a) fooked
B) not charging
How can I tell if it’s receiving a charge ?? Wot's that in old money
Post #545370 27th Feb 2020 6:31pm
It will be battery related!
Remove the batteries and bench charge them! Then refit them and check voltages whilst running... Thumbs Up
Post #545375 27th Feb 2020 7:22pm
Heyloft
Yep got that it’s battery related
The main battery is 98% charged and 13.8v so I’m happy with that.
The Aux battery after 2 hrs of charge is 10% charged and 10.2v. That’s just not right.
I don’t want to fix it, it’s under warranty, I just want to tell the dealer that they’re talking sh*te and it’s the aux battery not the main one, rather than them blaming the main starting battery again. I’m evidence gathering, I guess. Wot's that in old money
Post #545377 27th Feb 2020 7:33pm
Vogue
If you disable the Stop Start on the 4.4 it will also disable your heated seats 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #546575 9th Mar 2020 3:41pm
hasnt on mine...in fact everything works as it should.. ... - .- -.
Post #546578 9th Mar 2020 3:58pm
Vogue
It will Stan - yours is the V6 - it’s the SDV8 the heated seats stops working on 👍🏻 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #546602 9th Mar 2020 6:30pm
interesting..i wonder if any other 4.4 owner has this problem.. ... - .- -.
Post #546608 9th Mar 2020 6:39pm
JNC
United Kingdom 2011 Range Rover Vogue SE TDV8 Nara Bronze
Following on from this. Has anyone done a diag/iid tool scan after disconnected the aux battery?
We have customers L405 3.0 V6.
Fault codes
U0447-00 Invalid data received from gateway A
Also code for Aux battery.
DPF keeps getting full.
Vehicle conditions incorrect for regeneration.
Just eliminating that possibility from equitation.
Post #579895 15th Jan 2021 6:34pm
ive never had a dpf warning since the mod and never since ive had mine...
everything works as it should.... ... - .- -.
Post #579900 15th Jan 2021 7:17pm
JNC
Do you have fault code for battery when you scan vehicle?
Post #580076 17th Jan 2021 12:14am
mines a capacitor so no battery fault code. ... - .- -.
Post #580082 17th Jan 2021 8:25am
Page 4 of 5 <12345>
