![]() | Home > Technical (L322) > Auxillary belt and Pulley replacement - MY12 TDV8 |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3817 ![]() ![]() ![]() |
Sorry Plato but I am on holiday at the moment in Tenerife and the Internet is slower than 3rd Class Post, so struggling to post anything.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35633 ![]() ![]() |
Nino,
Stan,
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Just go into your gallery, you can post a pdf file in there, then grab the url/link for your forum post .
Thanks Joe, I will give it a try when I return home next week to the joys of my mega fast internet connection rather than this 3G wet string link |
what tim says mike..load the pdf as a pic the old way and copy/paste the link.. |
I have sent you an apology in a PM. |
Plato69 Member Since: 14 Apr 2016 Location: Felcourt Posts: 7 ![]() ![]() ![]() |
Many thanks guys for your advice hope the hols went well Mike. Stan
Don’t be fooled by the use of gaffer tape, or the good lady’s gardening glove this is a professional job. ![]() ![]() Access was a tight, defo Xmas list for the ratchet tool nino-nino & taken onboard the use of a set of ramps.
Thought I could shortcut the bespoke fan pulley spanner with a well-placed breaker bar or pry bar but to no avail. Found out the hard way was being too smart for my own good, So have succumbed to its purchase & will look into knuckle replacement on the NHS!!
Looking at the state of the old tensioner the spring casing is badly cracked so was probably independently planning its own spectacular war out.
Will update further once the fan pulley tool arrives and daylight permits, but probably next weekend, & the big put back together ![]() |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
I made my own holding tool and use crescent wrench to undo the bolt, it is LH thread
Plato,
Mike. G reg 2.5VM Vogue Portofino red 1991- 1999 V reg 2.5td P38 Rioja red 1999- 2006 53 reg td6 Vogue Oslo blue 2006- 2015 11 reg 4.4 TdV8 Vogue SE. Baltic blue 2015- date. https://www.fullfatrr.com/forum/topic56162...tty+affair |
Sonearly Member Since: 18 Sep 2020 Location: Northants Posts: 218 ![]() ![]() ![]() |
A rubber seal comes with this pulley , anyone know where this should be please. Pic posted |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
Great post going to wait for warmer weather to do mine |
