Home > Technical (L322) > P040D-00 (2F) EGR temperature sensor replacement
Page 2 of 10 <12345678910>
j9ffy
France 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
[quote="gonna_go_double_r"]j9ffy - great effort! I do think you may have had less trouble using the ratchet arm I got, but you've also proved it's possible with something else! Well done. And good luck getting the new one in.
Many thanks! Giving it a rest until the 6850 tool arrives ... allow my knuckle swelling to reduce Very Happy
Post #515320 14th May 2019 3:55pm
j9ffy
Six point version of the special tool arrived this afternoon (outstanding price/delivery speed to France etc from an online auctioneer in uk). Took five mins to bed-in the sensor ( I did this "just so" - really didn't want to over-tighten it). GGDR is spot-on about being careful not to cross-thread it, so I had spent a couple of hours yesterday getting the sensor carefully offered-in etc... I'd pay close attention to getting this right.
Another two hours(!) to get the heat shield bent back into place and the two securing screws back in.. the one under the sensor is a pig.
Fired-up, IID tool on, check codes - showing: PCM-Engine TDV8 4.4L P040D-00 (2F) Exhaust gas recirculation temperature sensor A - circuit high.
Cleared codes. Checked codes. Fault code gone! Checked around sensor for any signs of blowing/smoke etc.. all good... test drive good.
GGDR - ur a star - many, many thanks!
Beer-o'clock.....
Post #515652 17th May 2019 7:27pm
GGDR
Really glad it worked out, well done!
It's a pig of a job but worth it, so satisfying to see the error code gone.
. Cheers, Greg
Post #515719 18th May 2019 1:08pm
Corsica
France 2011 Range Rover HSE TDV8 Santorini Black
Bonjour j9ffy
Pouvez-vous regarder vaut message privé sur le site merci
Post #516077 21st May 2019 12:01pm
j9ffy
Evening all - just going back to Corsica's question a couple of posts ago... what would be the effect of cutting the sensor and then driving the vehicle with the sensor cable severed? My guess is that this is effectively just going open circuit so could be tested by simply disconnecting the sensor at the harness connection to see what the effect is (eg putting the vehicle into limp mode etc..). I'm afraid I didn't check this whilst doing my repair so don't know the answer for certain... does anyone happen to know?
I think the basis for understanding this is whether cutting the cable could make things "worse", particularly given how hard the sensor might be to remove from the manifold.
Any steer on this might be useful - am I correct in assuming that simply undoing the connector would be an effective cutting of the wires as a test?
Best,
J.
Post #516733 27th May 2019 10:38pm
GGDR
Yes well you could just undo the connector for a test. It won't go into limp, it will be the same as a failed sensor and the error will continue to show. So not too much point.
Another member - I think he had a 405 - tested his new sensor before he started all the work, plugging in the sensor (but uninstalled in the manifold) removed the error code.
So that is a better test than a disconnect, at least you will know it will clear the code before all that work.
But there's no fudge for long term - if that what you are thinking Corsica. Cheers, Greg
Post #516736 28th May 2019 6:16am
aids22
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Rimini Red
Hi All
Just done this job.
Thank you very much for the write up.
Followed the Instructions and it all went well.
A few extra things to add from my experiences.
This is what I used to apply WD40 it is a USB camera on a bit of bent wire and a small pipe to feed in the oil.
The camera was not much use but the light on the end let me see where to aim.
One way to prove that the sensor is at fault is to measure the resistance of it, mine was open circuit.
Just to confirm that the error would clear before I paid for a new sensor I tested it with a resistor in the connector.
With the ignition on you can clear the error with your IID Tool and it should not come back.
The resistor can be anything from 200 ohms to probably a few thousand ohms. The new sensor was 200 ohms at room temperature.
Do not start the engine with the resistor in place, who knows what it will do with a false reading.
I cut the old sensor off using a small cutting disk on a flexible extension you have to be very careful not to cut the metal pipe that is close to the sensor.
I then used a ½” long socket which is slightly smaller than 13mm giving a snug fit, just gently tapped it on with a small hammer.
Probably did not need such a good fit as it came undone quite easily, but not worth the risk of rounding it.
The heatshield bolts are stainless so you should get them out ok.
When putting them back in I tied some thin thread to the bolt to retrieve them when dropped and just pulled the thread off when the bolt was started. They are stainless so you cannot use a magnet to get them back!
I made a long extension to get the bottom heatshield bolt.
Anyway all done Very Happy Thanks again!
Post #525435 19th Aug 2019 5:42pm
GGDR
Nice work, and nice additional tips!
Well done.
Thumbs Up Thumbs Up
. Cheers, Greg
Post #525453 19th Aug 2019 7:11pm
j9ffy
Thumbs Up Thumbs Up this job certainly tickles ze problem solving leetle grey cells! Nice solutions & well done.
I might get a t-shirt printed .....
[/img]
Post #525795 21st Aug 2019 10:22pm
M@r]{
United Kingdom 2012 Range Rover Autobiography 4.4 V8 Barolo Black
Any idea if having this fault code present would prevent a DPF regen?
Post #537967 20th Dec 2019 9:42am
GGDR
Not at all in my experience
. Cheers, Greg
Post #537968 20th Dec 2019 9:47am
M@r]{
Ok, that sounds good. Do have another question. In your other thread you mention this can be a cause of a full DPF?
https://www.fullfatrr.com/forum/topic48068.html
I have this fault EGR sensor fault (along with a red Restricted Performance dash warning) and whether or not the Restricted Performance warning is related to the fault code or not, I'm concerned that driving the car could have a negative effect on the DPF? Is that a risk? My soot levels are at 20.1g (not sure at what point it will do a regen)
Post #538000 20th Dec 2019 12:51pm
GGDR
That's why I changed the sensor - to find out if that was helping to fill my DPF.
Alas not, I've had no change to what I call regen range - that is my range from 0 or low grams soot to 20g soot.
The original post is 18 months old, I think if you could be bothered reading all 18 pages after that (!) it's mentioned in there somewhere. Will amend the OP.
Your main issue is you can't regen on a RED warning, you need to clear that red.
Post up your code(s)....
. Cheers, Greg
Post #538006 20th Dec 2019 2:08pm
DrRob
Code has no impact. Lots of evidence of that from multiple folks Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #538007 20th Dec 2019 2:19pm
M@r]{
Ok, all makes sense, thanks both.
Post #538010 20th Dec 2019 2:25pm
