Home > Technical (L322) > P040D-00 (2F) EGR temperature sensor replacement |
j9ffy Member Since: 27 Mar 2018 Location: Indre Posts: 33 |
Six point version of the special tool arrived this afternoon (outstanding price/delivery speed to France etc from an online auctioneer in uk). Took five mins to bed-in the sensor ( I did this "just so" - really didn't want to over-tighten it). GGDR is spot-on about being careful not to cross-thread it, so I had spent a couple of hours yesterday getting the sensor carefully offered-in etc... I'd pay close attention to getting this right.
17th May 2019 7:27pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3542 |
Really glad it worked out, well done!
18th May 2019 1:08pm |
Corsica Member Since: 03 Jan 2019 Location: Corse Posts: 50 |
Bonjour j9ffy
21st May 2019 12:01pm |
Evening all - just going back to Corsica's question a couple of posts ago... what would be the effect of cutting the sensor and then driving the vehicle with the sensor cable severed? My guess is that this is effectively just going open circuit so could be tested by simply disconnecting the sensor at the harness connection to see what the effect is (eg putting the vehicle into limp mode etc..). I'm afraid I didn't check this whilst doing my repair so don't know the answer for certain... does anyone happen to know?
27th May 2019 10:38pm |
Yes well you could just undo the connector for a test. It won't go into limp, it will be the same as a failed sensor and the error will continue to show. So not too much point.
28th May 2019 6:16am |
aids22 Member Since: 10 Jun 2019 Location: Warrington Posts: 27 |
Hi All
19th Aug 2019 5:42pm |
Nice work, and nice additional tips!
19th Aug 2019 7:11pm |
this job certainly tickles ze problem solving leetle grey cells! Nice solutions & well done.
21st Aug 2019 10:22pm |
M@r]{ Member Since: 03 Nov 2019 Location: Northants Posts: 165 |
Any idea if having this fault code present would prevent a DPF regen? |
20th Dec 2019 9:42am |
Not at all in my experience
20th Dec 2019 9:47am |
Ok, that sounds good. Do have another question. In your other thread you mention this can be a cause of a full DPF?
20th Dec 2019 12:51pm |
That's why I changed the sensor - to find out if that was helping to fill my DPF.
20th Dec 2019 2:08pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
Code has no impact. Lots of evidence of that from multiple folks Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
20th Dec 2019 2:19pm |
Ok, all makes sense, thanks both. |
20th Dec 2019 2:25pm |
