![]() | Home > Maintenance & Mods (L322) > Deployable Side steps misbehaving |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3866 ![]() ![]() ![]() |
My passenger side steps start to retract on locking the car but come back out as though they have hit an obstacle. Had a quick look nothing seems to be fouling the mechanism.
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 ![]() ![]() |
Are they clean and well lubed? Bish.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35482 ![]() ![]() |
as above..might have picked up some crud ...check connections and lube.. |
EmiratesA380 Member Since: 14 Jan 2015 Location: england Posts: 352 ![]() ![]() ![]() |
Oddly SWMBO locked the car yesterday and the steps retracted OK, so its not just me frightened of her |
supershuttle
Charles89 Member Since: 11 Nov 2018 Location: Leicester Posts: 268 ![]() ![]() ![]() |
WD40 Is water displacement and the 40 is the batch composition number. It took them 40 attempts to get it right, it was originally going to be called water displacement... but 40 attempts to get it right later.. and so the name was born.
WOW Pilots - next time I'm on the bus I'm going to ask the driver how to service it. |
I wouldn't know how to! I don't service my own aircraft |
Ticketyboo Too Member Since: 19 Mar 2015 Location: Kilkenny Posts: 38 ![]() ![]() ![]() |
Yep Supershuttle,
xjrsupercharger Member Since: 09 Feb 2014 Location: Weybridge, Surrey Posts: 8 ![]() ![]() |
The only time mine played up on a 2008 TDV8 a thorough clean and re-grease fixed it! 2015 L405 SDV8 Autobiography
Bingo_123 Member Since: 19 Sep 2014 Location: Essex Posts: 173 ![]() ![]() ![]() |
That should i clean the sidesteps with, As right now, the driver side one is misbehaving almost everyday.
Actually I gave them a good going over with the jet washer then re-greased the moveable parts with waterproof grease and kept moving them in and out until they were working properly 2015 L405 SDV8 Autobiography
