Home > Maintenance & Mods (L322) > Deployable Side steps misbehaving
supershuttle
My passenger side steps start to retract on locking the car but come back out as though they have hit an obstacle. Had a quick look nothing seems to be fouling the mechanism.
Anyone else had this problem? Geoff
Post #500915 8th Jan 2019 12:42pm
bishbosh10
Are they clean and well lubed? Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #500922 8th Jan 2019 2:02pm
as above..might have picked up some crud ...check connections and lube..
Post #500926 8th Jan 2019 2:15pm
EmiratesA380
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Aintree Green
again - Think this is the Famous Wedge Key - in the system
have posted this on another thread a few moments ago.
IF THE WEDGE KEY IS WORN OR OUT OF ALIGNMENT THEN IT WILL CAUSE THE SYSTEM TO KEEP REBOOTING !
Post #500932 8th Jan 2019 4:27pm
DJM911
United Kingdom 2009 Range Rover Vogue TDV8 Buckingham Blue
So I am not the only one with this issue. We will be starting a club soon on issues with deployable side steps for Range Rover owners lol
We should keep an eye on each other’s threads. A few good points raised on mine this evening.
I am having trouble finding new wedges to buy online. Can’t even find what they look like. If anyone knows where I can get them or even see a picture of them please. 2009 Land Rover Rang Rover Vogue TDV8 - Buckingham Blue with Ivory Leather - 20” Alloys with Pirelli’s
Post #500980 9th Jan 2019 1:16am
supershuttle
Oddly SWMBO locked the car yesterday and the steps retracted OK, so its not just me frightened of her Rolling with laughter
On a more serious note what do people use to lube the mechanism as I have not done so because I am wary of debris sticking to grease would a thin spray like GT85 used regularly do it? Geoff
Post #500987 9th Jan 2019 8:56am
EmiratesA380
supershuttle
You will know I a stickler on service reports & what people have done on maintenance !
On our L322 - every month without fail
Spray large amounts on Silicone Spray over all moving edges ( NOT the dreaded WD40 - in the aviation world its not good name - as as it says on the title - Water Displacement for 40 days !!!
When the Silicone has removed all the debris / road film
Then coat with oil can - light machine oil over all moving parts ( inside and facing outside - there are a few linkages that MUST be oiled on regular basis )
Also CHECK the Wedge Keys for alignment & seating on collar puller - things can move and wear
The L322 we have are 12 model years and we have had no issues with the self deploying side steps ( if this helps )
As with the 380 - serving and maintenance is paramount !
Post #500991 9th Jan 2019 10:46am
Charles89
United Kingdom 2014 Range Rover SVAutobiography SDV8 Scotia Grey
WD40 Is water displacement and the 40 is the batch composition number. It took them 40 attempts to get it right, it was originally going to be called water displacement... but 40 attempts to get it right later.. and so the name was born.
I have no idea what these wedge keys are your referring to?, any pictures at all...
Also I am assuming you pilot A380s... Bow down we share something in common, I work for HM Royal Air Force, and I too am a pilot.
Post #501179 11th Jan 2019 7:53am
supershuttle
WOW Pilots - next time I'm on the bus I'm going to ask the driver how to service it. Rolling with laughter
Please don't on my account have an argument about WD40, I know what it does and what it's properties are. It looks like a good clean and lubing with a light lubricant might help, I'll give it a try later - thanks all for your input. Geoff
Post #501181 11th Jan 2019 10:01am
Laughing
Post #501184 11th Jan 2019 10:04am
Charles89
I wouldn't know how to! I don't service my own aircraft Rolling with laughter
Post #501192 11th Jan 2019 11:11am
Ticketyboo Too
Ireland 2010 Range Rover Vogue SE TDV8 Zermatt Silver
Yep Supershuttle,
On occasion the near side step will retract and a second or so later it will extend again upon locking. I have attributed it to picking up loads of crap being on the side closest to the verge. I make sure to lock them out extended when giving the old girl a wash and find that all is well. If this wee bit of attention is all that's required for the benefit of having them then it's one of the more tolerable pains of FF ownership. I've has 2 significant issues caused by my MD remedied by another garage this week, so I 'll be visiting the MD in the next few days to test his language comprehension skills... Censored Censored FF MY2010 3.6 tdV8 VogueSE
Post #502932 27th Jan 2019 11:07am
xjrsupercharger
The only time mine played up on a 2008 TDV8 a thorough clean and re-grease fixed it! 2015 L405 SDV8 Autobiography
ex 2008 RR Vogue TDV8
ex 2001 RR P38 4.6 Vogue
ex RR Classic
Post #503061 28th Jan 2019 4:37pm
Bingo_123
That should i clean the sidesteps with, As right now, the driver side one is misbehaving almost everyday.
On close inspection, i found the there is lot of dust/grime/mixed with previous lubricants struck at the parts inside.
So ideally i have to clean all this without causing any damage and then spray grease etc.
So what shall i clean it with? any suggestions
i reckon i will need a brush and some sort of oil to remove all the crap, so what should i use to clean it.
Thanks
Post #511810 12th Apr 2019 11:35am
xjrsupercharger
Actually I gave them a good going over with the jet washer then re-greased the moveable parts with waterproof grease and kept moving them in and out until they were working properly 2015 L405 SDV8 Autobiography
ex RR Classic
Post #511813 12th Apr 2019 11:53am
